My CK20 Manual Transmission
   / My CK20 Manual Transmission #1
unkajed
My tractor now has 25 hours on it. Since day one, I have heard a knock. Perhaps I am not use to a diesel engine. I don't know.
Basically:
I turn on the ignition switch to glow plug. The glow plugs stay on for about 8 seconds or so. Glow plug light goes out.
I start the engine: Oil lamp/light goes out and I adjust engine speed to approx 1500 rpms and I let it warm up.
When I start it I hear knock, knock, knock. I hear this sound regardless of load, no load, rpm, transmission engaged or transmission not engaged.
The tractor is not smoking whatsoever.
I can make the knock go away by quickly lowering the rpm's via the throttle lever.
Let's say I am idling the engine around 1500 rpms. I adjust the throttle level all the way down to 1000 rpms which is the minimum rpm and the sound goes away until I guess it starts the injectors again to supply fuel to maintain the minimum rpm. Then the sound starts again.
Perhaps I am hearing Ignition Knocking.
Even though I am at 25 hours, I am considering changing the oil in case the tractor set on the lot for a while and perhaps the filter failed, is failing or something. Maybe the factory uses cheap engine oil for initial break in.
I know one thing. When I do change the oil, I am going to run the old oil through a pair of women's hose just to see if I have any metal particles.
If it is ignition knock, what can I do to quiet it down?? Higher centane rating?
It has not failed but it defintley sounds different than a gasoline engine.
I called my dealer and basically he said don't worry about it unless it fails.
Any suggestions or comments???
   / My CK20 Manual Transmission #2
It's probably just diesel knock but that is a diagnosis from xxx miles away without listening to the machine. Take it for what it's worth.
I have noticed the Daedong engines are MUCH louder than some others. My previous tractor was a Kubota and it purred once it warmed up. The 'ol Kioti definitely make more of a racket. I don't mind it really but I was surprised at first.
Thanks.. I am thinking the same thing. Especially since you say it is MUCH louder than some others.
Kill the fuel the knocking stops, re-apply the fuel, it starts again. Adjust the rpm downward and it stops.
I know if it was a rod or something, I would hear it all the time. I once has a car with a bad connecting rod bearing and it made noise when I applied gas or not. It never went away.
Maybe I am just freaking out.
Thanks again!.
{I would be pissed tho if something failed on this thing with just 25 hours on it since I bit the bullet and paid it off last month. I know Murphy and his laws.}
   / My CK20 Manual Transmission #4
Kioti Growl!!!!!!!!!
:D:D:D:D:D:D:D
BTI
:D:D:D:D:D:D:D
BTI
lol
Kioti Knocking Howl.
I take it not to many of these engines fail?
   / My CK20 Manual Transmission #6
If it continues to bother you then perhaps you could run a similar Kioti at your local dealer to compare.
Excellent Idea! Thanks
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
Miller Welder (A51691)
