My case 580B has a reset button on the dash, can anyone tell me what it does?
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #1
somanytractors
atlanta, ga
several
I've attached a few pics.
I have no idea what this is for.
It just says push to reset, and it looks like a hose coming out of it and going under the hood.
I didn't trace it because even if I did find where it goes, I still wouldn't know what it does.
Any info would be greatly appreciated
Yellow Machine Fastener Rust
Yellow Rust
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #2
That's the air filter restriction indicator.
Once the air filter is clogged enough, it will trip that little indicator to warn you to clean or replace the air filter. It will show a ring on that clear section of it, probably red or yellow or similar. Once the air filter is either clean or replaced, you push to reset the indicator.
EDIT: As they say, a picture is worth a 1000 words. This should make more sense:
ptsg, Thanks soooo much. I would never have figured that out.
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #4
Reset the Flux capacitor?
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #6
Resets you back to 1980
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #7
It’s kind of like the undo button in software if you screw up.
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #8
Resets the garage wall to be complete instead of having that hole you just put in it by accident
   / My case 580B has a reset button on the dash, can anyone tell me what it does? #9
Its a indicator from when your wife wants you to stop playing on the backhoe.
Just hit the reset button and she goes away.
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
2006 Isuzu NPR 16FT Box Truck (A50323)
2006 Isuzu NPR...
2018 UTILITY VS2DC 53FT REEFER TRAILER (A52141)
2018 UTILITY VS2DC...
2007 Ford Expedition EL Limited 4x4 SUV (A50324)
2007 Ford...
2012 Ford Fiesta Hatchback Sedan (A50324)
2012 Ford Fiesta...
