My breaker panel
   / My breaker panel #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
I just bought what I thought was a 24 space 100 amp main panel.When I mounted it I happened to look at the spots for the breakers and there is only room for 20,not 24.Upon further examination I see that the metal enclosure is marked correctly on the inside for 24 breaker and so is the outer metal cover with 24 knockouts.The box had been opened and taped back up.It seems someone switched the inside "circuit board' for a 20 spot one.I am fine with 20 spots as it's in a garage but will the panel pass inspection like this?.I'll have to leave the 4 bottom breaker knockouts in the front cover as I can't put breakers behind them.Ok to pass inspection like this?.Thanks.
   / My breaker panel #2
Why take the chance, take it back and get what you paid for.
   / My breaker panel #3
I would just take the 'guts' back and and get them to swap it out..
Shouldn't be a problem if you have the receipt and box...i've had to do it several times.
   / My breaker panel
This was the last one they had in stock and now I know why.It's mounted and I'll use it if it will pass like this.
Kennyd, I would but all they have left or smaller panels right now.
   / My breaker panel #5
Call the inspector and tell him your situation...see if you properly mark the panel "20 circuits" if he will let it fly.
If not, I would make the place you bought it from find you the guts, even if they had to special order it at their expense.
Good luck.
   / My breaker panel #6
I can't imagine anyone caring about that. The only issue I could see was if someone poked out the spots and there was a direct shot at the bus bars. Keep the knock outs in and you should be fine.
That from me along with $.50 will get you a cup of coffee. (Small) haha
   / My breaker panel #7
....and they make replacement knockout covers for use when a breaker is removed later. MikeD74T
   / My breaker panel #8
I don't think there's any problem here. If you read the sticker afixed to the inside of the panel it will explain the "problem" your having. You see, in most panels the bottom few spaces are approved for "tandem" breakers. By using tandem breakers you can get two circuts into one "space." I'll bet your bottom two spaces on each phase are aproved for tadem breakers, hence you have room for 20 breakers, but 24 circuts.
   / My breaker panel #9
I was thinking the same as woodlot. That is the way my GE panel is.
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
UNUSED LANDHONOR LDH-FPR36 - 36" FIRE PIT RING (A54757)
UNUSED LANDHONOR...
2015 Hyundai Veloster Hatchback (A55758)
2015 Hyundai...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
