my Bobcat ct335 doesn't start when outside temperature is below 50 degrees.
   / my Bobcat ct335 doesn't start when outside temperature is below 50 degrees. #1
Bowhunter32
Bobcat CT335 2009
When the outside temp is above 50+ degrees, tractor starts fine. below that temp, it just spins no ignition. already changed glowplug relay. any suggestions?
   / my Bobcat ct335 doesn't start when outside temperature is below 50 degrees. #2
Check your battery.
Under 50 degrees is not very cold, so there shouldn’t be any gelling or other cold weather related issues.
All of your fluids clean and full (oil, fuels, hydraulic)?
   / my Bobcat ct335 doesn't start when outside temperature is below 50 degrees. #3
Still sounds like a glow plug issue.
Have you tested for power at the glow plugs ?
   / my Bobcat ct335 doesn't start when outside temperature is below 50 degrees. #4
Check voltage to glow plugs, and check glow plugs to see if they are shorted or open.....
   / my Bobcat ct335 doesn't start when outside temperature is below 50 degrees. #5
I agree that it sounds like a glowplug issue.
Depending on where you are, 50 degree days may be few and far between this time of year.
On my old Ford when I was having troubles with cold weather starting several years ago I stuck either a hair dryer or heat gun into air intake, and it helped it start. At least a way to get it running. I don't remember if I replaced any glow plugs, but the glow plug indicator seemed to be wired in series with the glow plugs, and had a wire that had burnt in half.
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
2020 INTERNATIONAL LT625 DAY CAB (A51222)
2020 INTERNATIONAL...
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
Hayrack (A50515)
Hayrack (A50515)
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
