My biggest project yet - a rear blade.
   / My biggest project yet - a rear blade.
View from the other side. The parking stand is temporary - I will get another piece of square tubing that fits inside the one I stuck on the side of the main beam. For now this round rod works OK.
Here is a top view in an angled position. A 14" stroke cylinder will give me an angle a little less than this, I think. I don't need much angle anyway - just enough to spill snow off to the side.
DONE! All prettied up and hanging from the tractor. I decided to paint the blade with rubberized rock guard/truck bed coat instead of ordinary paint. This stuff is pretty tough and should last longer than ordinary paint. Besides, I like the black against green contrast.
... and another ...
... and another.
Well, that's it. Hope you all liked it.
Now, how many rear hydraulic outlets do I want ....
   / My biggest project yet - a rear blade. #27
Brad… your welding looks MUCH better than mine… Nice work, nice project, and nice photo documentation. Thanks for the view. KennyV.
   / My biggest project yet - a rear blade. #28
Brad....
"Fine Job" Bud, this shows the true wealth of experience & know-how of the members here at TBN. You, my man are a "craftsman", like I said before, Good Job. On my list for winter projects inside out of the cold, is a landscape rake; I hope you don't mind me borrowing some of your ideas ??
Eric
   / My biggest project yet - a rear blade. #29
Great !
Ok, next job... Build a snowblower for the front /forums/images/graemlins/smile.gif /forums/images/graemlins/cool.gif
   / My biggest project yet - a rear blade. #30
Nice job. Looks like you could make a rake attachment for it also, you would just have to unbolt your 4 bolts etc .
LOT: Tap & Die Set, Hole Saw Set, Snap Ring Plier Set (A59076)
LOT: Tap & Die...
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
UNUSED FUTURE 32"...
1985 Ford Ltl9000 Tender Truck (A56435)
1985 Ford Ltl9000...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
