My B7100 is broken
   / My B7100 is broken #1
KJINTF
Alaska
Ford
Thought I would show a few pictures over here of my broken baby
Noticed the front end wobbling way more than it should have been
After a closer look see - WOW it's cracked in 1/2
Purchased the little baby new in 1993 and it has only has 850 hours
O' Well I guess "#@it" happens :mad:
Has anyone else experienced this mess?
How did you get it repaired?
Anything special I should look for?
Not too difficult a job getting at the broken part
I Hope all I need is $375.00 and two weeks delivery for a new part
Have a great day
Ken
   / My B7100 is broken #2
Normally I would say just have it welded back together, but if that axle frame is only $375 I would go that route. I have been around Kubota's for 25 years, 12 of those as a dealership mechanic and have never seen that failure on a Kubota.
Brian
Thanks Brian
Strange stuff seems to happen to me - O' well life goes on
Looks like the factory weld had a few small steel pipe reinforcements added during the manufacture / fabrication of the part. These pieces were placed right at the place the thing cracked in half, wonder if they knew it was a weak point
How much "play" should there be between the hanger bolt sholder for the front axle and the hole in the part?
I can feel a small amount of wobble with the sholder in the hole
Both the bolt sholder and the hole show signs of a small amount of wear
Was thinking going the welding route as well if the hole did not get reemed out too much
Found the part #66740-51210 on the web for $350.00 but shipping might be a killer for me - we live in the back woods of western Montana
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2015 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
BESTWAY AG VSK50 LOT NUMBER 104 (A53084)
BESTWAY AG VSK50...
TEYME 2000 E0L0 GTE10 LOT NUMBER 228 (A53084)
TEYME 2000 E0L0...
