My Appalachian Lean-to build in Iowa
   / My Appalachian Lean-to build in Iowa #1
Capt Dan
LeClaire, Iowa
First time new post. 3rd. try
Wanted to have a dry place to throw ball for the dog so I build this inside last winter. I have a separate building I was was able to build it in on the weekends then loaded it on a trailer and brought it the 30 miles home. Has come in very useful and can see it from living room. I was using it every day until I broke my ankle 2/16/14.
I used tractor to dig the spot in fall and moved it in end of Feb 2013.
   / My Appalachian Lean-to build in Iowa #2
Very nice! Did you put it directly on the ground? is it treated wood? This is exactly what I want to build.
Yes, I made the base all out of treated wood. It's Two 10 foot 4x6's then 6 foot 2x6's and 3/4 treated plywood. It's sheathed with 1/2" OSB. The back side is all steel without the cedar. The ground is probably starting to contact the back side now but didn't think it will be much of a problem.
The dimensions are 6 by 10 feet.
   / My Appalachian Lean-to build in Iowa #4
Nice. It is amazing the things we will do for our dogs.
Your right. I forgot to mention he's the reason for the broken ankle.
The Cedar I used for the vertical outside and the interior are Cedar Pickets for fencing. Wish I would have made them ship lap on the interior but I got in a hurry. Two bundles of shakes did the cables and had enough left over for the cables of a log rack.
   / My Appalachian Lean-to build in Iowa #6
Very nice looking building and I hope your ankle is healing well.
   / My Appalachian Lean-to build in Iowa #7
nifty shed. BTW looks like a Galvanized culvert for your firepit backdrop. Galvo bad. Fire good. Galvo and fire together not good. " I didn't inhale"
   / My Appalachian Lean-to build in Iowa #8
Is that a Standard Poodle?
It's a Golden doodle.
Yeah I know about the galvanized being bad. I've changed the wooden decking on the ground to some concrete pavers and am working on a different reflector. I made a fireplace out of a 55 gallon drum sideways but it's still not quite right. I need a taller flue and maybe it will work better.
   / My Appalachian Lean-to build in Iowa #10
The best thing I have done for both me and my lab was buy a tennis racket. I can hit the ball 3 times as far.
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
2018 Bobcat E26 Mini Excavator (A53421)
2018 Bobcat E26...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A53421)
2018 Toro Z-Master...
2021 Exmark Lazer Z 60in Zero Turn Commercial Mower (A52377)
2021 Exmark Lazer...
2020 INTERNATIONAL LT625 SLEEPER TRUCK (A54607)
2020 INTERNATIONAL...
