My 5010 is here.....
/ My 5010 is here..... #23
TE I think you will like the tractor....you must have lots of spraying and mowing to do. The manual says to be careful with the types of filters you use when spraying chemicals??
Do you mean the use of charcoal filters ??
I have not read the manual yet:ashamed::ashamed::ashamed: I have been to busy.
Busy getting seat time I hope. The book just says use a Active Carbon Filter while spraying then replace it with the paper one. Not sure if that means a new ACF each time you spray or if you can use it more than once??? Good luck hope you enjoying yours like I am mine.:thumbsup:
/ My 5010 is here..... #26
I'm really digging that set up. Cab TnT, hyd. rear blade:thumbsup:
Hope you have a lot of fun, safe hours behind the wheel.
That is what's called an oxymoron. :laughing: I don't know if it can even be done. :rolleyes:
Hey glad you made it back home safe and sound. Sorry I could not make it up the other day. Well hope the pictures help others jump one way or the other about buying this brand or any other for that matter. :thumbsup:
MTM, yes this set up is just about perfect for what I do with her. Before the TnT and the rear blade set up I was always on and off the seat(old tractor) adjusting this and that out back. Now after hook up I really never have to get out of the Cab until its lunch time(very important). I am also putting my Pats quick hitch system on this tractor that I took off my old one. Had to order another thinner shim before I can install it but should have it on by next week. Makes hook up real easy and I really like easy!!
/ My 5010 is here..... #29
It was a good trip, got to meet Mary and Scott, Dave was not around. :( We were able to get many sizes that we did not have before. I believe that we will be doing business in the near future. :thumbsup: Thanks again for the referral. ;)
I was wondering if they called you after seeing your set up on the back blade? Both Scott and Dave really liked the way it turned out. I was up at the shop this morning talking with Dave about more goodies for the tractor. I have got to stop going there it always cost me money!!!! Good luck.
60in. Work Bench (A65640)
60in. Work Bench...
Hedge Posts (A65640)
CASE 850M WT CRAWLER DOZER (A64277)
CASE 850M WT...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
2014 Infiniti QX60 (A62613)
2014 Infiniti QX60...
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
