My 3 point trailer hitch project
   / My 3 point trailer hitch project #11
Now just weld some hooks on and get a hook for reciver and you can pull trees or post out of ground.
meanmerc,
You might try bolting the receiver to the underside of the drawbar, then you can use a plate on top w/the same bolts to weld the upright bar to. That's the way I'm thinking I should have done it, since the ball is a bit higher than I anticipated.
Then you can unbolt the receiver anytime to move it to your bucket if you like.
Jim
I got the same idea, I already bolted the receiver to the drawbar now just have to weld up the up bar but I've been hesitating now cause I might use that receiver and bolt it up to the bucket (FEL) instead!!!:confused:
johndeere4300,
It's actually the pin that is sticking inside. I think the lip on it is catching, like the holes in the receiver and tongue aren't lining up correcly. I briefly tried a punch, but didn't spend too much time on it. I'd probably have just wound up crushing the end, or snapping off the end if I had continued. I'm sure with a bit of wiggling and patience, I'll get it apart.
Thanks,
Jim
<snip>
Jim,
That is a nice job you did also and we like pics. here on TBN.
You said it was stuck in your hitch.
Can you take a piece of 2x4 and lay it against the ball and hit the 2x4
with a small sledge and get it out.
Thanks for the pics.
   / My 3 point trailer hitch project #14
johndeere4300,
Thanks,
Jim
Ok.
I understand you now,
Anyway you could take a drill press and drill both of them.
   / My 3 point trailer hitch project #15
yeagisyeag, yes hindsight is 20/20. But that is what I like about steel, it is usually very forgiving. Easy to cut it apart, grind it off and do it again. I have been using mine for over 10 yrs and was thinking it seemed a little high bolted on the top. There have been situations where mine was needed very close to the ground.
Meanmerc, bolt it below the drawbar and add a plate to weld the upright for the toplink to. Very easy to unbolt and use on rear or on front bucket.
   / My 3 point trailer hitch project #16
This is what I built last Summer. Hauls trailers, pulls logs and it serves as a weight box as well. I can add 600lbs of ballast on the 3ph that is including the weight of the contraption.
   / My 3 point trailer hitch project #17
Great ideas from all! Thanks for posting Is there a need to limit uplift travel with the hitch?
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
CHINESE 125 ATV (A54757)
CHINESE 125 ATV...
BUCKET TRUCK (A56858)
John Deere 4600 (A53317)
John Deere 4600...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
