Mx6000 fogs up on the inside when pushing snow.
   / Mx6000 fogs up on the inside when pushing snow. #11
mine also has a lever for switching air flow from exterior air for makeup to recirc air. i find it frosts the glass alot more if its on recirc
   / Mx6000 fogs up on the inside when pushing snow. #12
Yep. Thats why I asked if it pressurized?
   / Mx6000 fogs up on the inside when pushing snow. #13
One thing;the cabs are pretty well sealed and in winter we drag in some snow on our boots;so there is bound to be a lot of moisture in the air.As stated turn on the air and open a window for a while.
Or breathing. Need to stop breaking & pumping out warm humid air.
Like others have said, A/C dehumidifies air. Just make sure you drink a lot of water to avoid dehydration working in really dry air. I end up parched plowing snow in a cab with heat & A/C on.
   / Mx6000 fogs up on the inside when pushing snow. #14
does the mx6000 have defroster grids... I have the same problem on my GL4740 if I forget to turn on the A/C. Like others said, defrost on, fan on high, A/C on, and I think most important; fresh outside air not recirculate.
   / Mx6000 fogs up on the inside when pushing snow. #15
With our Jack Russell in the cab,I always seem to need A/c and a side window open to stay defogged.
2016 Isuzu NPR 15ft. Beverage Truck (A55852)
2016 Isuzu NPR...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
TANK MANIFOLD (A55745)
2012 Ford F-550 Crew Cab SWAT Transport Truck (A55852)
2012 Ford F-550...
UNUSED FUTURE SF60 HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
1993 HONDA 300 FOURTRAX ATV (A57192)
1993 HONDA 300...
