Mx6000 fogs up on the inside when pushing snow.
   / Mx6000 fogs up on the inside when pushing snow. #1
ptlawn
None
Dealer basically told me that there isn’t a fix for this. Has anyone else came across this? If o what did you do to fix it?
TIA
   / Mx6000 fogs up on the inside when pushing snow. #2
Happens to me all the time. I usually run defrost on high and temp slid over to hot with AC on. Dries out the cabin air.
ya we tried that. Didn’t work
   / Mx6000 fogs up on the inside when pushing snow. #4
Turn the AC on,dries the air+open a window.Been plowing with my cabbed Kubota for ten years and no problem.
   / Mx6000 fogs up on the inside when pushing snow. #5
Mine steam up windows when first starting up moving or blowing snow. I crack 1 window and press a/c button on while setting temp on highest heat. After all fogging is gone, i can close window and turn off ac compressor, and fog never returns. Been like that for 10 years now.
   / Mx6000 fogs up on the inside when pushing snow. #6
Sounds like the factory heater & blower isn't up to the task.
Add a supplemental 12V heater and fan pointed at windshield if needed. I was in a wheel loader that had a 12v heater/fan combo screwed to the dash to keep the windshield clean.
   / Mx6000 fogs up on the inside when pushing snow. #7
Same here. I run the ac and heat together and have the fresh air vent open. Never had a fogging issue.
   / Mx6000 fogs up on the inside when pushing snow. #8
   / Mx6000 fogs up on the inside when pushing snow. #9
I run a road grader in a wide range of temps. I never turn off the AC. Just regulate the temp with the heat knob. Sometimes when I first crank the grader in cold temps (10F or less) it will fog the windows for about 5 minutes. After that, no problem.
Not being familiar with your tractor, does it pressurize the cab when the heat/AC fan is running?
   / Mx6000 fogs up on the inside when pushing snow. #10
One thing;the cabs are pretty well sealed and in winter we drag in some snow on our boots;so there is bound to be a lot of moisture in the air.As stated turn on the air and open a window for a while.
John Deere 3038E (A50120)
John Deere 3038E...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2002 KENWORTH W900 TRI AXLE (A52472)
2002 KENWORTH W900...
2012 Hyundai Elantra Sedan (A50324)
2012 Hyundai...
2011 Kubota KX080-3 Midi Excavator (A50322)
2011 Kubota...
PT 8' Offset Disc (A50121)
PT 8' Offset Disc...
