MX5100
/ MX5100 #1
budepps3760
Montgomery, Al
Mahindra 2810
Bought this tractor yesterday and it's a significant size upgrade from my previous tractor. St some point in time I will buy a larger Bush hog. How large a cutter would this tractor operate?
/ MX5100 #2
The general rule of thumb is 5 horsepower per foot, by that you could run a 10 ft bush hog.
Realistically speaking, if you are not running in heavy grass, you could probably run anywhere from a 10-foot to a 15-foot, you will just need to go slower with the 15-foot.
I might lean towards a 12-foot batwing just because it would be easier to move on a trailer if you need to move it someplace (no overwidth permit needed).
Aaron Z
/ MX5100 #3
We have a MX5800 and bought a Woods BB720x (7') and it works great.
/ MX5100 #4
If you're thinking about 3 pt. hitch type, remember you have to be able to pick it up. I think Kubota publishes data on how heavy an implement can be for each machine. Check your operators manual.
For my L47 the max recommend is a 6ft cutter weighing 926lbs.
/ MX5100 #5
For MX5200 it is an 84 inch 1000 pound cutter max according to manual
Andy
/ MX5100 #6
There's a big jump in price when you go from a 72" to a 84". Unless you are doing large areas the extra foot may not be worth while. If you go to a mid or HD cutter the weight can go up too. I have a 6ft Bushhog 286, which I'd call a medium duty and it weighs 962lbs. The 7ft cutter in the same series (287) weighs 1247lbs, which would be a little heavy for your machine, IMO.
/ MX5100 #7
I have an MX5100 and 7' or 8' would be all I would want. It's true that you have to be able to lift it if 3PT mounted.
/ MX5100 #8
Note that if you're going to a 7-foot, you'll probably be just as well off going with an 8 foot as an 8 foot is usually twin spindle bush hog so it doesn't stick out as far in the back and can be easier on the tractor to lift and get into tight spaces.
Aaron Z
Pallet of Fork and Frame Mini Skid Steer Attachment (A61567)
Pallet of Fork and...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A62131)
UNUSED WOLVERINE...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
2018 BMW X1 28I SUV (A61569)
2018 BMW X1 28I...
UNUSED KJ 25'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 25'X12'...
1999 INTERNATIONAL4700LPX 4X2 BOX TRUCK (A59908)
1999...
