Loader mx5100 loader lift capacity
   / mx5100 loader lift capacity #1
dbaer78
nashville,indiana
kubota mx5100hst
Hello to all! I ve been looking on here for awhile and finally signed up. I want to replace my old 3600 ford with a new MX5100 here in the next month. it will see a lot of time in the woods with my wallenstein fx90 skidding winch. I would like to make sure, however, that the la844 loader is stout enough for my tasks. How big of a log will it handle? Pics anyone?:thumbsup:
   / mx5100 loader lift capacity #3
if heavy lifting or curling is what you are after I thinkyou will be dissapointed.
I have a la844 on a L5740 and it is not the same loader as my old Davis loader on a MF35
Best advice is to figure out the weight you expect to move then try to test drive the machine you choose.
Mine has been tested for pressure and it comes back as fine but I find my loader hits the relief often particullary in the curl
   / mx5100 loader lift capacity #5
That loader will lift just under 1700# in the bucket and I was under the impression that it was a well built loader.
   / mx5100 loader lift capacity #6
Yep, you need to know the approximate weight of the logs.
A grapple bucket will help. It will get the load closer to the tractor and allow you to lift more than bucket forks too.
But the Loader on that tractor rated @ ~2400 @ pins is about the norm for 45-60HP tractors. Tractors in that size are usually between 2400 and 2700.
Even a M6040W/1153 loader is only good for ~2600lbs@ pins. And a kioti DK55 (which typically have strong loaders) is 2800 @ pins. And the really big Mahindra 5530 is only good for ~3000.
It takes a 75HP+ tractor to get over the 3000lb mark.
So I guess to answer you question "how big of a log will it handle", I'd say pretty close to the same as any other tractor under 60-65HP. If you need more capacity, you are going to have to step up to a MUCH larger tractor.
   / mx5100 loader lift capacity #7
I guess the JD 5000e series are an anomaly here then.
We have a 5045e Deere at the farm and the loader is very impressive for a 45hp tractor. It lifts over 3100lbs at the pins to max height, and over 4000lbs at the pins to 5' height. Also has a lift height of 122".
This may be an option for the OP if loader performance is a primary concern. The 5045e is priced about the same as the MX4700/5100, but is only available with the sync-shuttle transmission, no HST. With that said, from what I have seen I do really like the Mx Kubotas. Having a hydrostatic transmission on this size machine would be a very nice feature.
   / mx5100 loader lift capacity #8
The spec I saw on that....553 loader...JohnDeere 553 Loader Utility Loaders Material Handling Equipment JohnDeere.com
was only 2917lbs @ pins.
Deere muddys the water a bit (and others are starting to do it as well) giving a spec @ 59" lift. And yes it is much higher. 1000lbs higher to be exact. But that doesnt mean the deere will out-lift another tractor rated @ only 2900 to max height, because they ALL will lift more to a lower height. The loader travels in an arc. And the higher you go, the steeper the angle gets on the cylinder. Thus reducing its capacity. Kubota doesnt publish the "59" capacity" but just guessing based on the ones that do, the kubota is probabally capable of ~3300lb lift @ the 59" mark.
So I guess what I am saying is....when comparing loaders...BE EXTRA SURE you are comparing apples to apples. IE: Pins @ max height to pins @ max height. Dont try comparing pins @ 59" to Bucket center @ max height. This will give you false comparison.
   / mx5100 loader lift capacity #9
Here is the info directly from the link you posted:
Bucket used General Purpose - 73-in. (1850 mm)
Bucket weight, lb. (kg) 392 (178)
Lift capacity at full height, lb. (kg) ---
Measured at pivot (U) 3133 (1424)
Measured at 500 mm ahead of pivot (V) ---
Measured at 800 mm ahead of pivot (V) 1956 (889)
Lift capacity at 59 in. (1500 mm), lb. (kg) ---
Measured at pivot (W) 4008 (1822)
Measured at 500 mm ahead of pivot (X) ---
Measured at 800 mm ahead of pivot (X) 2891 (1314)
Boom breakout force, lbf (kgf) ---
Measured at pivot (Y) 5378 (2439)
Measured at 500 mm ahead of pivot (Z) ---
Measured at 800 mm ahead of pivot (Z) 3604 (1635)
Bucket rollback force capacity, lbf (kgf) ---
At maximum height (VV) 3877 (1759)
At 59-in. (1500-mm) lift height (XX) 5544 (2515)
At ground level line (ZZ) 3860 (1751)
Also, Kubota does rate the loader lift capacity at 1500mm lift height (59") in addition to the full height spec. With that said, Kubota doesn't as readily post this info as Deere does. Some Kubota models they post this in the spec sheets, others you have to look in the owners manual. For example, they post the 1500mm specs for the L4600, L3800/3200, but I haven't seen it in the specs for the Grand L's or the Mx4700/5100.
Not trying to argue with you, just giving the OP another option.
Thanks to everyone who has replied. ive compared the mx5100 to every tractor in its class. yes, the 5045e does have probably one of the stouter loaders out there but i dont like the tranny. Ive looked and carefully compared loader specs until my head is spinning. A 2000# log is pretty normal for me and ive drug out much bigger than that. I dont need to be able to pick up EVERY log but i want to be able to pick up most of them. I was just hoping someone had some real world experience with one of these tractors in the woods because i know specs on paper dont mean everything. If i do decide the mx is to small i really like the m5640 too but its quite a bit more money.
PALLET OF MISC OUTDOOR PLANTERS (A51244)
PALLET OF MISC...
Vermeer 5410 Round Baler (A50774)
Vermeer 5410 Round...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
John Deere 4455 (A50120)
John Deere 4455...
2025 72in Rock Bucket Skid Steer Attachment (A50322)
2025 72in Rock...
2020 Chevrolet Express (A50120)
2020 Chevrolet...
