Mx5100 let me down!
   / Mx5100 let me down! #1
CJBOTA
Salem, Ohio
Kubota B2620 & MX5100
My buddy at work lives down the road called and ask if I could bring my tractor down and offload a woodstove from a trailer. I said no problem, I'll be right down. Even though it was raining a little I headed out to help him. I pulled in his drive and holy cow, there was one of the biggest outdoor furnaces I ever saw sitting up on a trailer. Although it had a lifting hook on top, I immediately thought there is no way will I pick this thing up. He said he thought it weighed about 1000 lbs. I had my tiller on the back with about 300 lbs of steel plate on top. I figured about 1000 lbs. I had to raise the bucket as high as it would go. I just had a nice hook welded to the center of the bucket. I did not feel very good about this lift. Sure enough just as I got it off the floor of the trailer, the rear end came up on one side and I came as close to rolling her over as you can go without it actually happening.
I only have 30 hours on my MX5100 and I must say it is a totally different machine with the loader off. It doesn't feel right even when the loader is empty. ( bounces like crazy) I guess I am going to have to get the tires loaded, but I am not confident that will be enough. Now that my needs have changed I am not sure if Kubota builds heavy enough tractors for my needs. I used to think this light in the rear end thing was an overstated problem. I don't think that after tonight. Using the loader on the MX5100 is a dangerous proposition. The only thing that saved my butt tonight was my operator skills.
I have heard many brag about these MX5100's on this forum, but please be careful with these loaders. I am not sure what you can safely lift but it is only a fraction of what the hydraulics are capable of. The MX5100 is way to light in the back
CJ
   / Mx5100 let me down! #2
CJ
I have had many similar experiences on several tractors. Always light in the rear end. No matter how much weight you have, it is never enough. :confused2: Sorry to hear that your Kubota didnt have the ballast to lift that stove off the truck. :( I wouldn't get rid of it though just because it wouldnt lift your neighbor's stove, I would only trade it in if you plan to lift large loads like that all the time. :eek:
   / Mx5100 let me down! #3
I think you'll find with the loaded tires, it's a completely different machine. I don't have much time yet on my new L5740, but my old L3710 would lift a 1000 lb propane tank at max loader height with loaded tires and 6 ' finish mower on back with no problems. I had to stack them in my barn for hot water storage. My wood boiler weigh about 1600 lbs, and I also moved this around with my L3710 with no issues, and that's a much lighter tractor than your MX. A lot of dealers require either loaded tires or ballast box when selling tractors with FEL. Loaded tires should add around 1000lbs on the rear if you use Rim guard.
   / Mx5100 let me down! #4
I have a 5100 and i know exactly what you mean. i bought mine and the tires we not loaded. I couldn't lift a full bucket of gravel and feel comfortable moving around with a bucketfull. I then loaded the tires and it does make a lot of difference.
However, all tractors have their limits.
   / Mx5100 let me down! #5
Just for fun, the minute my L3400 came off the truck I ran over to the gravel pile and picked up a bucket of 0-3/4 and the results were scary. I quickly built a 750 lb ballast for the rear and that was not enough either. I picked up a big rock, and the wife said the rears were off the ground 2 foot:eek::eek:
I loaded the tires. So much better.. I can tell you your 1000 lbs in the rear and unloaded tires are not near enough for picking up heavy objects. My tractor is much smaller and I have almost 400 in the tires and 750 on the 3pt. and it is just about right for it.
James K0UA
   / Mx5100 let me down! #6
Sorry to hear of your pucker-inducing experience, CJ. Take heart; you're not alone, and the solutions are pretty straightforward. The old 2wd farm tractors used to have 60-70% of their weight in back, but these modern 4x4 setups - doesn't matter what brand - are, if anything, front heavy and really need some serious weight in the back. However your 400 lb bucket + that 1000 lb stove hanging 3 ft out beyond the front axle out weighed the 600 lb tiller (just my guess) + 300 lb weights that were probably about the same distance off the back axle.
In addition to tire ballast and more weight in back, here's a couple of other things - maybe they are obvious, but probably worth mentioning anyhow. First, try to do any heavy, high lifts on a dead-level surface with no pot holes or soft spots. Next, be sure your load is secured so it's evenly balanced and won't swing laterally. When you have a heavy load up high, any one of those things can get a tip-over started because you are balancing that heavy load on the pivoting front axle.
Glad you and tractor are safe and it didn't end badly for you.
   / Mx5100 let me down! #7
Keep in mind some of these furnaces are more than 1000lbs. Plus you were at the top of your reach?
I have an indoor boiler and dry it weighs 1200lbs. And physical dimensions it's 3 times smaller than an OWB.
   / Mx5100 let me down! #8
The light has it's pluses and minuses, I don't tend to use my machines on manicured lawns, so the light factor is if anything a negative for me. I do have all of my machines with loaded tires though, really helps with stability, but even with the most weight you can't always predict what's going to happen. Neighbor was looking to buy a tractor, test drove my 3120, moving a big rock on a 10 degree slope with the loader 2' above the ground, and it was just high enough that the back tire was about 2' off the ground. Once he got where he was going he turned it off and told me I had to take it back:laughing:. A lot of it simply can't be controlled. One time I was on a 3 degree slope and decided I wanted to know how high my 5410's bucket could go, before I got to the top I felt it starting to come sideways, my heart hit the floor and I dropped the loader. Lesson learned is not to do anything stupid and don't rush because **** happens and you can't take it back.
I would definitely add rim guard possibly some cast iron wheel weights and a large ballast box filled with cement, or a heavy box blade. You'll put an easy 2k pounds on with those and maybe closer to 2.5k pounds.
   / Mx5100 let me down! #9
Interesting. Both my M9 and my 105 have cast iron centers on the rears and while I can get the backend light (on both), I'm hard pressed to get either side off the ground.
I'm against tire loading because of the aggrivation involved in changing a tire plus CaCl destroys rims.
   / Mx5100 let me down! #10
Yep they are light. I am assuming that your hook on the bucket is welded on the top? That being the case means the chain goes over the front of the bucket which means you are lifting at the front of the bucket. A long ways ahead. Lift as close to the pins as possible and you will have a lot better luck.:thumbsup:
CATERPILLAR 819 PADFOOT LANDFILL COMPACTOR (A51242)
CATERPILLAR 819...
2018 TAKEUCHI TB240 EXCAVATOR (A51242)
2018 TAKEUCHI...
UNUSED JCT QUICK ATTACH 84" GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
2021 Dodge Durango GT AWD SUV (A50324)
2021 Dodge Durango...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
