mx5100 hydraulic hook up for backhoe
/ mx5100 hydraulic hook up for backhoe #1
ford farm boy
Indiana
Mx5100,9N,ford 2000
I have a mx5100 can someone tell me , draw a picture , take picture , of how the hydraulic lines come off of tractor for the bh90 backhoe .I am wanting to make me a set of remotes set up like that to run a post driver , log splitter so I don't have to tie the handle back on the other remotes.
Thanks
Someone has to have a bh92 backhoe on a mx5100 that can help.
/ mx5100 hydraulic hook up for backhoe #3
Here is some photos of my MX4700,LA844,BH92 it's the same as a MX5100
Supply comes from the loader valve and the return line is down next to the hydraulic filter on the fluid block plate..
hope this can help ya..
/ mx5100 hydraulic hook up for backhoe #4
I have the BH92 on an MX5100 and can take pics but wildcatblue is right, it's the same on the MX4700 and his pictures look good. Not sure whether you need more info.
So if I under stand it right 1 hose from pb from loader block to remote for backhoe .Then 1 hose from other side of remote to return to block under deck . Just a loop ? So if the backhoe is not on do you loop a hose in the remote or is the remote block open center?
Thanks guys
/ mx5100 hydraulic hook up for backhoe #6
It's just a loop from tractor to backhoe, supply and return. do not use 3 point lever when backhoe lines are attached. keep lever in the down position..
/ mx5100 hydraulic hook up for backhoe #7
On the backhoe for my L3130 they disconnect the line for the 3Pt and hook the backhoe up and the return from backhoe to the tank line, this disables the 3pt hitch and speeds the backhoe up as all the fluid in not going through the 3Pt valving.
David Kb7uns
INOP/NON-RUNNING 2012 Ford F-450 Ambulance Truck, VIN # 1FD0X4GT2CEB23465 (A65563)
INOP/NON-RUNNING...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
1960 IH Farmall Cub Tractor (A66285)
1960 IH Farmall...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
