MX5100 HST HST noise
   / MX5100 HST HST noise #1
horses2
Bronze Member
Westminster, Md
Kubota M471D
I have an MX5100 HST that has been very reliable. It has developed what seems to be a bearing noise when in mid range or high range. the noise doesnt occur when loaded at lower speeds and not at all in low range. the noise is different from the trans whine.
all fluids are changed on schedule, using Kubota filters and fluids.
Any thoughts or suggestions?
   / MX5100 HST HST noise #2
How many hours when you noticed noise? Are you running udt or sudt2?
update: the tractor has 178 hrs. I had changed the hyd filters and topped off the fluids per the owners manual. I had used UDT. After going thru some threads on fluids, I drained all the hyd fluid, changed filters again and this time used SUDT2. hard on the wallet, but the tractor loved it!! The trans has NO noise, and seems to run alot smoother.
the SUDT2 is hard on the wallet, but the tractor runs GREAT.
2017 Freightliner M2 106 24FT Box Truck (A50323)
2017 Freightliner...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
2 Row Planter (A52128)
