MX5100 Clutch Switch disable
   / MX5100 Clutch Switch disable #1
Waltert
Lunenburg, Nova Scotia
MX5100 HST
Hi All,
I read on the forums recently of someone disconnecting the clutch pedal switch to permit starting the tractor without depressing the pedal, having to climb aboard to start is a pain,,, where is the switch located?
Walter t
   / MX5100 Clutch Switch disable #2
My MX5100 (shuttle shift) doesn't need the clutch depressed to start -- just put the shuttle in neutral and she fires right up.
Found it under the dash,, made a jumper and it starts right up, I tried to start it with the HST pedal slightly depressed to be sure it will not start (in gear), it will not start. Not sure why the MX5100 has the clutch switch and the L4400 does not ?
Walter t
   / MX5100 Clutch Switch disable #4
The switch is located under dash near upper clutch pedal, dash cover around steering wheel must be removed to gain access, then just put on a scotch lock to the 2 wires from the the Clutch switch, and bam your done. you dont have to change anything else, now the clutch harness thinks you have the clutch pressed down when starting..
   / MX5100 Clutch Switch disable #5
Mine works this way too.
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
2013 Nissan Pathfinder SUV (A50324)
2013 Nissan...
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A51222)
2013 FREIGHTLINER...
2018 Nissan Murano S SUV (A50324)
2018 Nissan Murano...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
