MX5000 VS M4800 VS M5700
   / MX5000 VS M4800 VS M5700 #1
mazej
Other than engine and HP, which is the best value of these 3 Kubota beauties...and what's a good price new for each w/o any options?
   / MX5000 VS M4800 VS M5700 #2
I just bought a new M5700, FEL w/quick detach bucket, hydraulic shuttle trans, industrial tires and a Bush Hog 286 for
$30,500. I was going to have the dealer order a M4900 but
this one being on his lot, was a much better deal.
   / MX5000 VS M4800 VS M5700 #3
The M4900 and M5700 are essentially the same tractor. The lifting capacities, hydraulic pump GPM, etc., specs are about (if not) the same. The M5700 has slightly larger tires giving it just a bit more ground clearance and the motor turns at a higher RPM giving a little more HP. You really aren't getting more tractor for your money by buying a M5700 over the M4900. But, if your dealer is giving you a M5700 for the price of a M4900 - then it is well worth it. /forums/images/graemlins/grin.gif
If you think you might need a bigger tractor then a M4900, seriously consider moving to a M6800.
In my mind, the best deal out of the bunch is one you haven't mentioned - the M4900.
Can't really help you on a price for a M4900, but we recently bought a M6800, FWD, hydraulic shuttle shift, canopy, two sets of remotes, FEL w/quick attach, skid-steer bucket w/teeth, and ag tires for $31,000.
   / MX5000 VS M4800 VS M5700 #4
I totally agree with tjkader.
I have a quote for a M4900 with R1's(loaded) and second set of remotes for $22,875. The loader adds another $4350. Tractors tend to be on the high side here in Maine.
I wish I could justify an M6800 but I can't. You also get a front locking differential with the M6800. Nice!
Dave
   / MX5000 VS M4800 VS M5700 #5
I will have to agree with these guys. I have compared all of these as well as NH and JD. The M4900 would be the best choice, if you need more PTO hp the M6800. I don't know what area you are from but I was quoted M4900, R1 tires,1 set of remotes for $19500 last month when I was getting serious about getting a larger tractor. But I decided to get a FEL for my 3130 instead and trade up in a year or two when I can afford a cab.
   / MX5000 VS M4800 VS M5700 #6
The MX5000 is in a much different class. They don't say it but if you have a chance, look over an L4610 (a discontinued model) and an MX5000. The MX5000 basically is gear drive 4610 with the L5030 motor.
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A50397)
2012 Freightliner...
40 Yard Roll Off Container Dumpster (A49346)
40 Yard Roll Off...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A50397)
Adams Load Out...
2017 FORD F 750 26FT STAKEBODY FLATBED (A45679)
2017 FORD F 750...
Cat TH407C Telehandler (A50397)
Cat TH407C...
2016 Volkswagen Passat S Sedan (A48082)
2016 Volkswagen...
