jcaron2
My MX5000 has developed an electrical issue lately, and it seems to be getting worse. The tractor will be running normally, when all of a sudden the fuel pump solenoid will begin clicking sporadically, and the engine will spit and sputter and eventually cut off completely. Even after it has stalled the solenoid continues to click randomly. Then, suddenly the problem goes away, and the tractor is back to normal for a while.
I've checked the switches at the seat, PTO, and gear shift, and they all seem fine. Besides, it doesn't seem like it would be one of those switches or else the starter would be affected as well, but it's fine.
I've also jiggled, jostled, and wiggled pretty much every wire connection on the tractor trying to fix the problem when it's happening or trying to reproduce it when it's not, and I've been unable to make any difference that way.
Unfortunately, I don't have a schematic of the electrical system or a parts list for the tractor, so I'm taking educated guesses as to what's going on, but here's what I've observed:
When running normally, the voltage at the fuel pump solenoid is 12V, so that helps me rule out the possibility of a resistive connection somewhere causing the voltage to teeter around some threshold where the solenoid turns on and off.
Unfortunately, I'm never able to reproduce the problem when I have my multimeter handy, so I don't know what the voltage is when the solenoid is clicking, but I'd be willing to bet a fair amount that it's fluctuating between 0 and 12V.
If I trace the wire from the solenoid back toward the front of the tractor, it eventually goes to a relay with four connections. Again, since I can't reproduce the problem until I put away the multimeter, I've been unable to diagnose if that relay is the issue.
Can anyone tell me if this is the OPC timer relay? Given that the OPC system gets inputs from the seat, the PTO, and the gear shift, it doesn't seem like four connections would be enough, so maybe it's another relay (e.g. starter relay)?
Either way, based on a couple of previous threads on this forum, my hunch is that the OPC relay is the source of my troubles, but I thought I'd see if anyone here has an opinion on the matter or some suggestions for further troubleshooting before I buy a new OPC relay.
Josh
Josh
