MX5000 Engine Question
   / MX5000 Engine Question #1
mikeg135
Really 2 questions.
I have a 2001 mx5000dt w 221 hours. When under a heavy load or if I quickly hit the floor throttle it will blow bluefish/white smoke. It will do this even at full operating temperature. Is this normal? Otherwise, it seems to run and sound fine.
Also, I noticed this weekend it blows a little smoke on the back side of the engine on the brake side and in a downward direction. I believe it stops after several minutes. I was only moving some brush after the ice storm so not under any type of load. It was doing this at idle when I noticed it. Any idea is this also normal?
Now a little history on the engine. It had a rebuild done by a qualified diesel mechanic about 50 hours ago due to a lower radiator hose blowing off while bush hogging.
   / MX5000 Engine Question #2
Are you using any oil?
Nope, not using any oil.
   / MX5000 Engine Question #4
How about coolant?
   / MX5000 Engine Question #5
Your injection pump may need to be timed.
The smoke at the back of the engine could be coming from a blow bye pipe, if it has one.
   / MX5000 Engine Question #6
Has the smoke been there since the rebuild? How many hours since rebuild?
2022 Club Car...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
WHEEL LOADER BUCKET (A46683)
WHEEL LOADER...
2006 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A45679)
2006 VOLVO VNL64T...
2016 Ford Explorer AWD SUV (A46684)
2016 Ford Explorer...
WHEEL LOADER...
