MX quick connect size
/ MX quick connect size #1
aarolar
Platinum Member
Augusta Ga
Kubota MX4800
Does any one know what size hose threads go into the female quick connect on the MX series loaders? I borrowed a pressure gauge to check my pressure with I'm trying to grab the adapter I'll need while I'm in town today.
/ MX quick connect size #2
I usually check the pressure on one of the rear remotes since the feed comes from the same hyd. outlet block as the loader. The thread is 1/2" NPT or 3/8" NPT on my MX depending on the size of the female adapter. This won't help you though if you're trying to diagnose a faulty loader valve.
/ MX quick connect size #3
Yup. All one loop, so use a convenient QD if you are looking for general pressure. Not relevant if you are troubleshooting something specific.
