Must remove the hitch?
/ Must remove the hitch? #101
Some of your hitches must stick out way further than mine. Mine only sticks out about 6 inches from the bumper. I can't imagine why someone would be walking past the back of my truck so close than their shin is six inches from my truck. How do they avoid their arm/side rubbing down the length of the tailgate??
exactly.
Heck on my f450, the hitch is actually recessed a few inches under the bumper area, and with a standard drawbar in.. it sticks out only about 4"
/ Must remove the hitch? #102
almost sounds like you are a proponent of the 'no personal resposibility- trip and sue' faction unless I'm reading the last few of your posts intents incorrectly?
Actually, you ARE reading me wrong. I take great responsibility in NOT getting sued. If it is a way for people to sue others, I chose not to test the waters by leaving the hitch in. This thread has many opinions on the hitches and why people chose to do what they do. Hey, it's a free country. I am now finding out that it is common for vehicles to get a bent frame from a rear impact. It seems it gets much worse the more of a drop your insert has. The damage can also happen if you are towing and you hit a vehicle and your trailer pushes on the hitch insert. Newer FS trucks get MORE damage because they use longer drop inserts which have more leverage. A common place for the F150 to bend is between the rear axle and the rearmost spring shackle......interesting.
/ Must remove the hitch? #103
I once saw a pickup with those extended drawbars used under long campers, but the camper was removed. The hitch stuck back almost 4 feet. It must have been the only insert he had. That is one that REALLY should have been removed after towing.
Bruce
/ Must remove the hitch? #104
Ok, that's why i asked. didn't want to take it wrong if not meant that way.
makes me wonder what the people do with delivery trucks that have those fold up lift defks. there are things sticking out all over. if they are gonna trip on a drawbar.. a lift deck might be a death sentence.
what about those dump trucks with permanent pintle hitches?
why are people walking sooo close to a vehicle that their arms must be touching it for legs to hit drawbars?
/ Must remove the hitch? #105
sounds like the truck had to back in or pull thru and be going the wrong direction for the drawbar to be between him and another vehicle. who wants to pull thru going the wrong direction? makes it hard to safely pull out.
That is EXACTLY what they are doing and most lots here have that type of parking.
In fact, a gal I know just had the front of her new car messed up because a truck backed into the parking spot ahead of her. The problem was he forgot he had one of those carry-alls stuck in his receiver. Like you said, it's more dangerous parking like that.
I like my life simple with the least headaches. I've never sued anyone and no one has sued me....I want to keep it that way too. :)
/ Must remove the hitch? #106
We have elderly people here that instead of using a walker, they hold onto vehicles as they walk. Truck's tailgate makes the best handle I guess. True, most inserts are short but I do have one that sticks out a good 6" farther than most. I also have some big drop (8-10-12") inserts that stick out a little more. Once I saw a vehicle parked in a lot with one of those RV hitches with the 2 arms sticking out 3-4 FEET!!!!! We get all kinds here.
/ Must remove the hitch? #107
How is it different than a mirror? How is it different than if I slip on ice and my head hits your bumper? If someone wants to find a lawsuit they will. I don't care how prepared you are. I am not going to change my lifestyle and be consumed with it. If it is legal for my hitch to be in then it is in.
/ Must remove the hitch? #108
yup.. backing into an angled parking spot is just a bad idea. puts you against traffic when you want to leave.. and if traffic is heavy.. you might be their a bit!
As to what's in the drawbar holder. i have a pretty good idea where my truck ends and the outside world begins, but i'd be worried about others not knowing where their car ends and my truck begins. i got my right front quarter panel clipped by a mini car backing into a parking space near me. busted their plastic mirror, tore my trim off, dented my front quarter at the flair, and cracked the edge of my lamp assy, luckily in a dry area of the lense that had no lamp behind it. People here are bad about crunching into dually rear fenders. there is a local body shop here that I think is putting their kids thru college fixing pretty much a steady diet of dually fenders. the 2 part ones aren't as bad as the unibody ones.
drivers here for some reason see them things and love backing into them or swinging doors into them..e tc.
/ Must remove the hitch? #110
Oh great so when they slip and their ring snags my tailgate and their finger gets de-gloved I get sued. Maybe I should screw some handicap rails around my truck to cater to the needs of others.
/ Must remove the hitch? #111
i agree. wet pavement and whoopps.. fall into a vehicle... i'm sorry ti happens. but it's not something to sue about. I've slipped in water in a parking lot. guess I should have sued the lot owner for not having a water removal system or water shade.
... missed my chance i guess...
/ Must remove the hitch? #112
Good point about parking in the far end of the lot. Good exercise and less chance of a clown opening their door into your vehicle or rolling a shopping cart into it. Even though the shopping cart pen is probably only 3 feet away.
/ Must remove the hitch? #113
I too tend to park back away from all the "action". (where it's safe)
/ Must remove the hitch? #114
When im towing my CRV with my motorhome and traveling in the right lane on highways, it's happened more than once that a merging car will have to slam the breaks on because they didn't see my tow vehicle. Hope it doesn't happen but it will be their fault.
/ Must remove the hitch? #115
i've had someone merge into my deckover gooseneck trailer behind my truck. and it has red/white dot table all down the sides and marker lamps... go figure...
/ Must remove the hitch? #116
It is almost like people trade common sense for states of obliviation when they are sleeping.
UPDATE!
New company wide email today!
First they apologized for implying that the referenced IL statue was state law when it wasn't (as quickly pointed out by people here) But they went on to reiterate that regardless of state law, we should be safe so ... ya .... that.... (i just summed up another 3" long paragraph in the email with that)
To which most of the reaction should be eye rolling "what happened to common sense" sort of thing. Like Is it my job to watch were I'm walking or is it the worlds problem to provide me with a perfectly safe place to walk.
These sort of philosophical questions seem to have a straight forward answer untill you get lawyers and insurance people involved.
/ Must remove the hitch? #118
That's what you think. My wife use to work at Walmart. The worst place to park was in the back. The parking lot was sloped to the back. As the carts that didn't make it to the corral start to roll they pick up speed. She said there was some large dents to vehicles of people that wanted to protect their vehicles from lazy and stupid people. Said the closer you park the less likely major damage would be done by run away carts.
/ Must remove the hitch? #119
i don't think out rot is sloped at all. carts pretty much statically stay. cart damage is from rude people slamming them into your vehicle!
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
King Kutter 5' 3Pt Tiller (A66285)
King Kutter 5' 3Pt...
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
KBH Tender (A63688)
KBH Tender (A63688)
Bobcat E42 (A60462)
Bobcat E42 (A60462)
