MUST READ! Mahindra CRD Full Diagnostic Manual with Check Engine Codes
   / MUST READ! Mahindra CRD Full Diagnostic Manual with Check Engine Codes #51
Well I’ve been fighting a P1801 all week with no success in getting it cleared with 5 different automotive scanners. Ended up taking to the dealer this AM. Simple click of “reset” on the PRV (pressure relief valve) and on my way I went with a $119 bill for an hour of labor. Was simply that the computer thinks the fuel rail pressure relief valve opened 50 times so it goes into limp mode. Damn electronics. I am changing the pressure relief valve because I shimmed it to verify that wasn’t the problem and it clearly wasn’t. I am changing the pressure sensor on the fuel rail because it was not extremely smooth on the FES Diagnostic software. This may be because the sensor is sticky. PRV was $40 and sensor was $150. Yes the service manual states they are not serviceable but that is bull. PRV part number is Bosch 1110010028. The fuel rail sensor is part number Bosch 0281002937.
While I was at the dealer, I was watching over the techs shoulder and the software he was using was called FES Diagnostic Tester V17.0. I am really in need to get my hands on a copy of this software so next time the computer hits 50 counts, I can just click reset myself. I even called Mahindra this week and they would not sell it to me. If anyone knows where I can get my hands on a copy of the software, please contact me via robinsonpowerstroke@gmail.com Thank you!
   / MUST READ! Mahindra CRD Full Diagnostic Manual with Check Engine Codes #52
Fantastic info - thanks for the link!
   / MUST READ! Mahindra CRD Full Diagnostic Manual with Check Engine Codes #53
I just stumbled across this link to a 361 page pdf for the Mahindra CRD Diagnostic Manual (Arjun Novo, Mahindra sub company)
http://kisandost.com/KisanMitraWeb/MarketBulletinView?moduleType=SubjectPartFile&FileName=203
I've only quickly browsed it but this appears to the mother of all Jackpots for Mahindra Owners.
Page 68 of the PDF starts the Diagnostic Code Manual
And will list all diagnostic codes.
The PDF is interactive, so you can click a topic and it will take you to that page, you can search, etc.
It tells you how to trouble shoot the error, what the causes are, etc.
Everyone should save this to their desktop immediately to have a hard copy.
It may not be your specific tractor, but i'm sure these codes are relatively universal.
Moderator should probably make this a sticky too if that's possible here.
Seriously this is what every single person has every asked for that has come here with problems.
I simply Googled what Jabonee reported in my thread for my check engine light "P1804 RAIL PRESSURE LIMITER OPEN" and this was the 4th link down with a full successful match.
I'm in shock....
This is legitimately a factory service technician manual with every single step...
-Haas
***edit with addition:if anyone is unfamiliar; you can look up almost all of the mechanical diagrams for your Mahindra tractor & attachments on the Mahindra USA site under the Parts Catalog. Those diagrams, along with this manual should allow you to cover a large majority of what's going on in your tractor (if it's similar to the larger tractors like the one listed in this manual)
here's the link to the mahindra site parts catalog
Object reference not set to an instance of an object.
I can't get that link to open
   / MUST READ! Mahindra CRD Full Diagnostic Manual with Check Engine Codes #54
PM me your email; pretty sure I have a copy saved on my desktop at home. Like I mentioned previously though; a generic OBD2 code reader gives erroneous read outs. I never tried a BUS CAN system. The technical troubleshooting section is invaluable though and you can diagnose almost everything yourself.
-Haas
I would like a copy too please. chadg1016@gmail.com. Thank you
   / MUST READ! Mahindra CRD Full Diagnostic Manual with Check Engine Codes #56
anybody out there want to share their pdf copy i would like to get it.
just in case i ever need it.
thanks
If you get it can you please share with me also. Thank you
   / MUST READ! Mahindra CRD Full Diagnostic Manual with Check Engine Codes #57
I'm in shock....
-Haas
The link you shared for the codes is gone can you please share it with me
Lincoln Electric Ranger 10000 AC/DC Welder Generator (A56857)
Lincoln Electric...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
3ft Teakwood Totem Pole (A57454)
3ft Teakwood Totem...
2019 TAKEUCHI TL12V2 SKID STEER (A52709)
2019 TAKEUCHI...
2023 54in Hooklift Dumpster 15 Cubic Yard (A56858)
2023 54in Hooklift...
ATLAS ELECTRIC SKEET DISC THROWER (A58376)
ATLAS ELECTRIC...
