muratori tiller grease fitting size on pto shaft
   / muratori tiller grease fitting size on pto shaft #1
rfhjr
Salisbury NC
John Deere 5220
I was writing to ask if anyone would know the size of the grease fitting on a Muratori tiller fitting which is on the pto joint connection nearest the tractor shaft. I contacted Muratori and they were unable to determine the size unless they had the tillers serial number since the machine is older its either painted over or fell off. It must be some metric size I have tried 1/4 in which is too large M6 x 1 is too small.
   / muratori tiller grease fitting size on pto shaft #2
If you have the old grease fitting - take it to O'Reileys or NAPA and match it up.
No old grease fitting - go to same or equal outlets and buy one of their multi packs. What you need should be in one of those.
They might have a multi pack with SAE and metric zerks.
   / muratori tiller grease fitting size on pto shaft #3
I have a tool with all of the grease fitting sizes but it requires the fitting to insert in the tools hole. I don't think it has the male sizes to insert in the fitting hole but it might. There are soooo many different grease fittings.
   / muratori tiller grease fitting size on pto shaft #4
You certainly hit the nail on the head - workinonit. My tractor with FEL, grapple and rear blade has three different grease fittings.
It's as though - nobody ever thinks of using the grease fittings that already exists. AH - new implement. We MUST create a new fitting for this implement.
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
2017 INTERNATIONAL PRO STAR (A52472)
2017 INTERNATIONAL...
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
