Multiple Neturals
/ Multiple Neturals #1
Kevee
Suffolk
MF 1547
Hi,
This is a bit of a newbie question but my tractor has multiple places to engage a gear or netural, you have the range selection and the direction setting e.g. high range, mid range, low range, netural and forward, backward and netural).
If I want to stop the tractor I can stop and get out with just the direction setting in netural, should I be doing this? Do I have to set both levers to netural? What is the point of having it in more than one place?
I also have a PTO which again has a netural, when do you use that? Do a lot of people just use the on and off?
Thanks,
Kevin
/ Multiple Neturals #2
You should always use two nuetral's and here is why.
One of John Deere biggest class action lawsuits involved the John Deere 350 bulldozer series made between 1965 and 1988. The 350 model, 350B and some 350C models did not have a slot in their standard transmission shift pattern to even put the bulldozer in neutral. These tractors have a hydraulic reverser so it can be shuttled between forward and reverse on the fly without stopping; something a bulldozer does all day, every day. But this reverser has a neutral slot.
The problem was, the lever was where the operator gets off and numerous people lost their lives when they hit the reverser lever on their way off the operators seat. This was especially true after the reverser linkage got worn over the years. I never was killed obviously, but I cannot count how many times I stepped onto the track, bumped the reverser lever and nearly got trampled. Now I have got into the habit of shifting BOTH levers in neutral before stepping off the tractor. In logging operations, this happens a lot...on and off, on and off...rinse and repeat...but it is the safe habit to get into.
With John Deere, the class action lawsuit was started because people physically could not shift the main transmission into neutral. By the time my John Deere 350D was made (my 1988 tractor), the tractor had the oversight corrected.
History lesson of the John Deere 350 be worthwhile or not, you would indeed be safer IF you got into a 2 neutral habit without question in my opinion. The worst case scenario with 2 neutrals is, you jump on and go to take off and realize you are in neutral on one lever. The worst case scenario with only one neutral is, you inadvertently shift the tractor into gear and run over yourself on the way out.
I once knew a man in Maine who was killed when he was shoveling sawdust into the bucket of a big loader. The bucket was full so the operator went to haul the sawdust off for dumping, and was in forward when he thought he was in reverse. When he went to hit the gas, he cut the man in half killing him. Would (2) neutrals have helped? I am not sure, but a second step might have made him think twice?
BUT...I admit I am probably the worst operator on this forum as I have got so complacent on certain things. I hope others really get into some safe habits right off the bat. That is not judging others, that is hoping others are more safe than me.
/ Multiple Neturals #3
Solid advice given. Use at least two neutrals. As I get older and read about more unnecessary accidents and injuries and worse, I find myself becoming more **** about my safety. I also do a lot of logging, getting on and off the tractor frequently, and it can get tiring with all of the shifting.BUT........ I have never heard anyone regret safety practices. W. Jones
10" Utility Blower Fan (A66408)
10" Utility Blower...
Gradall no crank no start (A61568)
Gradall no crank...
New/Unused CFG Industrial NT18K Mini Excavator (A65579)
New/Unused CFG...
2012 International WorkStar 7500 Truck (A64194)
2012 International...
New/Unused AGT Industrial YSRT14 Mini Skid Steer (A65579)
New/Unused AGT...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
