Multi use tool bar-hiller, cultivator,
   / Multi use tool bar-hiller, cultivator,
Pictures of the existing tool. I had originally had a middle buster style plow, very similar, but 2x6 channel and old lawn mower blades as the plow, but I sent it with the old Kubota when I sold that. This frame was just an extra I built years ago, and never used.
That red iron stuff on the right side, is a lame attempt at a row digger, using old scrap I picked up on the side of the road. The angle is Way to weak, and the 'plow' bottom isn't nearly heavy or heavy-duty enough to cut more than 4 inches in sand, without bending or twisting.
   / Multi use tool bar-hiller, cultivator, #12
Sometimes see single row cultivators for about $75-125 in mid. TN. Hardly ever see a hiller with the two disc blades for sale used, however.
   / Multi use tool bar-hiller, cultivator, #13
I live in NY with soil primarily consisting of clay and rock, so pretty much polar opposite of what you appear to have so my experience may not mean much. However, I have found primary/initial tillage or any tillage dealing with more than minimal trash requires a tool with both vertical and horizontal spacing between "points" as a general term. Your current design lacks spacing and clearance and unsurprisingly as you found behaves like a solid blade. Could also be described as similar result to a landscape rake or spike tooth harrow as well I expect.
Free material and experimenting can be good things but I would say for ground engagement your material is to lite. I would think 3/16" or 1/4" angle or tube would be a better choice. I have seen a number of different clamping solutions for the round rod normally used on hilling discs. 2 U-bolts thru a plate attached to the frame is one way. Another option is to use larger diameter pipe attached to the frame and then 2 set screws to hold the hiller rod in the pipe.
This is the current garden area. It's going to get extended when I finish the property line fencing. As shown, the rigged up scrap attachment does tear up ground, but it doesn't really dig a furrow. Garden has been a mess every year, after doing a ton of handwork, you miss a week, and it's an uncontrolled jungle. Thought process is, if I can mechanize a lot of the initial bed work, and weeding (even just a bit) I would keep it under control.
   / Multi use tool bar-hiller, cultivator, #15
Ms. Rocks insists on having hilled garden furrows. I fabricated something out of what I had laying around that semi-works, but the commercial version that would allow you to adjust your row widths would seem a better option.
However, I seem to recall some guys built their own frames and then used the discs you posted earlier.
I hate when people start a thread and never check back in; so, as a check back in; I had some crap metal laying around, mostly 30" 1-1/4"x3/16" thick angle, and other red iron type stuff; and wanted to play with the mig welder. So far, I've pretty much got the frame more or less ready; need to fab or buy lower arm pins; then the big question, how to attach the sweeps to the arms. Tool bar is 55" long
Some butt ugly welds, with some slag inclusions, some porosity, and some burn holes, just to rile people up a bit.
2014 Chevrolet Tahoe (A55973)
2014 Chevrolet...
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
Butterfly Artwork (A55758)
Butterfly Artwork...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F-150...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
