Multi purpose Grease
   / Multi purpose Grease #1
casey lb1914
Upstate, New York
Kioti LB1914
I've used Quaker State multi purpose grease for my utility trailers and been told not to mix grease's, anyone know who sells it, I've been buying it at Kmart, but they no longer carry it. Whats the word on Lithium grease is it better for trailer bearings? :confused:
   / Multi purpose Grease #2
If you switch to a new grease, wouldn't you just lubricate it until all the different brand grease came out? I think this is reasonable. My used tractor, bush hog, PTO, etc. did not came with a supply of the original grease used on the zerks. Therefore I had to use a different type of grease on all the zerks. It happens all the time.
Bob
   / Multi purpose Grease #3
Best practice is to keep with the same complex grease. If you used a Lithium grease in the past use a lighium grease now. This will prevent compatibility problems that can happen when you mix different grease types like lithium with polyurea.
Lithium based grease is a very reliable grease type that usually has a good high temperature operating range. Just find another lithium based grease and you should be fine.
   / Multi purpose Grease #4
Most is lithium but the label will say. The warning is to not switch greases of different bases. I would not worry about this at all unless you are lubing bearings.
I have known contractors who run two shifts and require their operators to grease at the beginning of their shift. Each operator uses a different color of grease. The one guy uses red lithium EP and the other guy the dark grey lithium so that you can always tell if the previous guy didn't grease.
   / Multi purpose Grease #5
I use a lucas red and tacky or the green boat waterproof grease in my trailer hubs
Hours : 1114 (A50323)
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2021 Chevrolet...
2018 FORD EXPEDITION (A51406)
2018 FORD...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
UNUSED FUTURE SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE SKID...
