Multi G134
   / Multi G134 #1
basstracker
cincinnati ohio
ford 1620
I have a 1992 ford 1620 HST it calls for G134 hydraulic fluid but I can’t find any. Is there a alternative? I have never changed the fluid, do you just drain and fill, change the filters or are there specific things you need to do? Thanks
   / Multi G134 #2
Welcome to TBN!
New Holland dealers sell it as MultiGrade 134™ Hydraulic Transmission Oil, but any good grade like Shell Rotella HD, Mobil Delvac, Deere Hygard, Kubota UDT, Tractor Supply Traveler will work fine.
   / Multi G134 #3
I have a 1992 ford 1620 HST it calls for G134 hydraulic fluid but I can’t find any. Is there an alternative? I have never changed the fluid, do you just drain and fill, change the filters or are there specific things you need to do? Thanks
most any tractor hydraulic transmission fluid would work.
Don’t get the old 303 junk.
It’s also called Hy-Gard, (Deere), Hy-Tran (IH), perma-tran (MF), tractor trans, trans/hydraulic, or UTTF.
Dealer fluid is always good, but any fluid the farm stores list as meeting current specs is ok.
If it’s rated for wet brakes you’re good.
   / Multi G134 #4
Welcome to TBN!
Yep.
I have experience with those Tractor Tech listed....New Holland 134, Shell, Mobil, Deere, and Kubota hydraulic transmission oils. All are excellent. I've never used the Traveler brand from Tractor Supply, but I don't have anything against it. My bias is to stay with the premium brands I know.
rScotty
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
2002 WACKER RD25 ROLLER (A54607)
2002 WACKER RD25...
2015 CATERPILLAR 930K WHEEL LOADER (A51406)
2015 CATERPILLAR...
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 78in Dual...
