Mule 3010 Rocker Gasket
   / Mule 3010 Rocker Gasket #1
RavensRoost
Phoenix AZ and offgrid weekend place south of Pres
John Deere 4500 and Mule 3010 (gas)
I have a 2006 3010 Kaw Mule with gasoline engine and it is time to adjust the valve lash. As the Mule lives at our weekend place 30 miles from anywhere and 100 miles from where we live, I did not want to start unless I had new gaskets. Then it occurred to me that maybe Kawasaki used neoprene gaskets and therefore would not have to be replaced.
Anyone know if the vlave cover gaskets are neoporene, cork, or formed in placed with silicone?
RavensRoost
   / Mule 3010 Rocker Gasket #2
I had my service done at the dealer, so I'm not sure about the gaskets, but I should be able to eyeball them an make an educated guess. I'll look at our 2004 model to see what it has and try to let you know tonight.
   / Mule 3010 Rocker Gasket #3
I've set the valve lash on two 3010 mules now, and I did not replace the gaskets. Since they had so few hours on them, the gaskets looked like new still. And they did not leak after the fact. It's a 15 minute job.
Wayne
   / Mule 3010 Rocker Gasket #4
Wayne
Nuthin' like having experience. I'll defer to that, especially since my driveway was covered in ice last night and I slipped into the house and forgot to look at the gaskets.:eek:
When you checked the valve lash, Wayne, did you find a need for adjustment or were they within spec?
Wayne
Thanks Wayne, thaks jinman. I went ahead and ordered new gaskets before I saw your post. It is sort of like having a spare tire and never needing it vs. the other way around. The fact that the Kawasaki "superstore" did not have the gaskets pretty much told me I didn't need them, but I get sort of paranoid about tearing into something if I don't have the parts to finish. Especially as it is really "Wife's Mule".
   / Mule 3010 Rocker Gasket #6
Yes, they were off slightly. It's hard to imagine it makes much of a difference, but the warning was pretty stern in the manual. If I recall correctly, one of the valves on each cylinder was a bit off. You probably know this, but take your time checking them, and making sure you measure them correct with the feeler gauge flat, and you should just feel it touching.
Good luck!
Wayne
www.flymha.com
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
Skid steer auger plate (A50322)
Skid steer auger...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
