Mulch to use around trees
/ Mulch to use around trees #1
KubotaSteve
Platinum Member
eastern panhandle of WV
Kubota B7800 with loaded R-4s
I purchased 50 of the Colorado Blue Spruce from Bailey's. I planted 45 of them outside and have the remaining 5 growing inside in pots. I planted them a little early and have been fortunate the frost has not killed them. Anyway my question is what type of mulch to use on these trees. I normally use hardwood mulch but I was thinking about using pine mulch since it seems to do better at keeping the grass away. Any opinions? I'm not looking to spend a fortune but if I don't put something around them, I'm afraid they will get mowed off or overtaken by grass or weeds as the trees are not that large.
I just wanted to make sure that the pine mulch would not kill the trees as I know pine mulch will kill certain plants and flowers. /forums/images/graemlins/confused.gif
/ Mulch to use around trees #2
How about spraying Round-Up around each one? That way the tree is not competing with the grass for water and you can see them when mowing. It would sure be alot easier than putting mulch down.
/ Mulch to use around trees #3
From our local organic guru - Howard Garrett:
"The best mulch in the world is shredded native tree trimmings from local trees. Shredded hardwood bark is the second best mulch, partially completed compost is next. Pine bark is the worst choice. It breaks down into a mucky material, if it stays in place - a rarity, it usually washes and blows out."
For more of his advice, see this page.
/ Mulch to use around trees #4
Like Gatorboy said, try Roundup.
I use Reward more than Roundup, though.
It works in 1-2 days, Roundup usually takes a week.
Just be careful with either one.... they kill what they touch.
/ Mulch to use around trees #5
Steve,
Any hardwood mulch will do your tree good. One thing that I have done and has worked well is to spread a layer of newspaper around the tree and then cover it with at least 4 inches of mulch. The newspaper will compost quickly and kill all the weeds underneath. The mulch then composts and will feed the soil underneath. Be sure not to lay the mulch too thick right on the tree as it can rob it of nitrogen during the composting process. I usually just pull it back from the plant a bit.
Hope this helps,
Greg
/ Mulch to use around trees #6
The mulch will help retain moisture, and can also provide some shelter of the root stock from extreme heat or cold.
/ Mulch to use around trees #7
</font><font color="blue" class="small">( How about spraying Round-Up around each one? That way the tree is not competing with the grass for water and you can see them when mowing. It would sure be alot easier than putting mulch down. )</font>
I agree to some extent. Spraying the round up is good but I still would put the mulch down. Mulch will hold the moisture in for the trees. We just had a bunch of pines transplanted in the the guy that sold them to us made us guarantee to put mulch down. So we did, mulch is cheap.
murph
Thanks fellas, I'll go with my original thought and stick with the hardwood mulch as that seems to be the consensus here. The newspaper is a good idea. How thick do you put the newspaper down? Would 3 or 4 sheets thick be too much?
/ Mulch to use around trees #9
Steve,
I have just used a single layer. That seems to be all it takes and it rots within a few months.
Greg
/ Mulch to use around trees #10
I've used 3 sheets in the past. It helps to wet it after you lay it out (and before the mulch) so it tends to "stick" and not blow around. Add some Preen Weed Preventative to the top of the mulch and you'll really stop the weeds.
/ Mulch to use around trees #11
Check to see if the Blue spruce is acid-loving. Lots of evergreens are. In that case, pine needles might be best.
In some areas, hardwood mulch can lead to black mold. Once it gets started, it's almost impossible to contain. The state had to move out of and is tearing down the old MVA building not far from me - black mold!
We use stone chips over weed barrier cloth in some spots and pine needles in others around out place.
Yep, the pine needles do a fine job of killing the weeds!
/ Mulch to use around trees #12
I kinda like the idea of newspaper and pine needles Plus a tall stake by each tree so they remain visible. Pine needles will be acidic so they fit right in with spruce. If you want blue spruce needles put some iron fillings around the tree.
Note: Some hardwood mulch like walnut may not be a good idea.
Egon
20ft trailer (A61569)
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
Grain-O-Vator Corn Sileage / Grain Feed Wagon (A66408)
Grain-O-Vator Corn...
TRAILER MOUNTED LIGHT PLANT WITH FUEL CELL (A65643)
TRAILER MOUNTED...
Manure spreader for sale / Excellent Condition / Make offer
Manure spreader...
Vision 250/50R15 77D Golf Cart Tires (A65579)
Vision 250/50R15...
