Muffler construction
/ Muffler construction #1
geneP
Platinum Member
Central Mississippi, USA
Case-International 385, Kubota L5450 w/LA1150A loader
The verticle muffler on my L2250 seems to be getting louder. There are no holes in the outer shell, but the noise is louder around the lower end close to the manifold. Does anyone know if the actual muffler is enclosed in a shell? If so, is the inner section available, or do I toss and replace the whole unit?
/ Muffler construction #2
Inside your muffler case are a series of baffles and perforated tubes. Over time these pieces will corrode and come appart; causing your tractor to get louder. What we usually recommend our customers do is just go to a local muffler shop and have a new muffler welded onto the factory bracket. It is a lot cheaper than buying a factory unit and works just as good.
/ Muffler construction #3
Gene, measure the inlet size on the old muffler and then go to Tractor Supply Company. You should be able to get a muffler for 30 bucks or less.
Thanks for the replies...I was curious if the "guts" were replaceable.
2022 EZ-GO ELITE...
2022 LEVEL BEST GB100 108" HYD GRADER BLADE (A65053)
2022 LEVEL BEST...
UNUSED JCT DB600 DUSTLESS BLASTER (A65055)
UNUSED JCT DB600...
2008 Toyota Camry Sedan (A64557)
2008 Toyota Camry...
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
