Muffler construction
   / Muffler construction #1
geneP
Platinum Member
Central Mississippi, USA
Case-International 385, Kubota L5450 w/LA1150A loader
The verticle muffler on my L2250 seems to be getting louder. There are no holes in the outer shell, but the noise is louder around the lower end close to the manifold. Does anyone know if the actual muffler is enclosed in a shell? If so, is the inner section available, or do I toss and replace the whole unit?
   / Muffler construction #2
Inside your muffler case are a series of baffles and perforated tubes. Over time these pieces will corrode and come appart; causing your tractor to get louder. What we usually recommend our customers do is just go to a local muffler shop and have a new muffler welded onto the factory bracket. It is a lot cheaper than buying a factory unit and works just as good.
   / Muffler construction #3
Gene, measure the inlet size on the old muffler and then go to Tractor Supply Company. You should be able to get a muffler for 30 bucks or less.
Thanks for the replies...I was curious if the "guts" were replaceable.
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
2018 DODGE RAM 3500 LARAMIE SERVICE TRUCK (A51406)
2018 DODGE RAM...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2010 Ford Escape Hybrid SUV (A51694)
2010 Ford Escape...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
