Muddy Fittings?
   / Muddy Fittings? #1
James Eric
My Danco garden tractor loader came with dirty hoses. If I replace all of the hoses and fittings, it will cost around $300. Some of the fittings are caked with mud. How can I clean the hoses or do I need to replace everything?
Thanks for your help and comments in the past and now.
   / Muddy Fittings? #2
Soapy water and a scotchbrite pad?
If they are greasy use Simple Green or Superclean or the like and have at it.
   / Muddy Fittings? #3
If you are talking about dirt on the outside, just hose them off. If tractors are not getting muddy, you are not using them enough.
Ken
   / Muddy Fittings? #4
Just clean them good. Or,
Your replacement hoses and fittings should not cost that much if you shop around. Try here.
Surplus Center
These are 1/4 in hose, but you get the idea.
You can also get the replaceable fittings and make your own hose.
Surplus Center - Hydraulic Cylinders Pumps Motors
   / Muddy Fittings? #5
You can buy a lot of soap, water and elbow grease for $300.
David from jax
   / Muddy Fittings?
Thanks everyone. The mud is just inside the fittings. I am okay with cleaning the hoses that are still in good shape. I was concerned about damage to the system of some dirt got in the controller. I will clean and inspect all lines before I put the loader back together.
I priced the hoses at Surplus Center.. and the pricing look okay.
   / Muddy Fittings? #7
How/ why is mud (as in dirt & water?) inside the hoses?
That is a bad thing.
But not what anyone would expect.
Are just the quick connectors dirty, fell in the dirt? They can be cleaned up.
If somehow you got a bnch of dirt inside the hoses all over the insides of the hoses, yes you do have a problem.
I'm not really sure where to go with this, as it seems like more is going on than we know about, so it's hard to really say what you should do?
--->Paul
   / Muddy Fittings? #8
If it is just dirt inside the openings of the open face quick disconnects, just clean them out and you will be fine. If you literally have dirt in the hoses (which is hard to imagine how), then that is a different matter. Perhaps pictures if it is not clear what we are saying?
Ken
   / Muddy Fittings? #9
If the fittings just fell in the dirt then just use wd40, airkoil, or something like that to spray on the fitting and then blow real hard on them! do it a couple of times and then you should be ok to reconnect!
   / Muddy Fittings? #10
pressure wash em...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52748)
2017 Rogator...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52748)
2022 Down2Earth...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2016 Hino 195h Truck, VIN # JHHSPM2H5GK001607 (A51572)
2016 Hino 195h...
