Mud Dauber in the keyhole
   / Mud Dauber in the keyhole #1
Steelstring
Columbus, Indiana
So a mud dauber wasp decided to take up residence in the key hole of my Series 1000 tractor. I've tried a small wire brush and compressed air, but i still can't get enough of the mud out to get the key in the hole far enough to turn it! :thumbdown: Any suggestions? Can you take those key switch units apart?
   / Mud Dauber in the keyhole #2
PB blaster is what I would use next, shouldn't take much. Oh yea, don't forget, it's flammable.
Thats a good thought! Yeah...that stuff is essentially gasoline in a can. Great stuff!
   / Mud Dauber in the keyhole #4
Same thing happened to me a few weeks ago. sprayed with WD40 and inserted a small copper wire to mash things up.
   / Mud Dauber in the keyhole #6
If you use PB blaster I wonder if the oil in it would gunk up the pins in the switch?
   / Mud Dauber in the keyhole #7
i thought PB blaster was not flammable or not as flammable as WD40.
have you tried a combination of vacuum cleaner, wire, and air gun from air compressor?
have you tried an actual "needle" like a larger size sewing needle? vs wire that may bend?
you might try, just taking key switch out (dismantal the dash, unhook wires) and pull entire switch out. so you can turn it upside down, and slightly tap it on something. to see if any dirt falls out.
having it upside down so stuff falls out while using some sort of spray, or air gun, or like. vs letting stuff fall back down into it, as you get stuff loose. would more likely help ya out better.
i would say call a locksmith. but by time you do that, it may be easier and cheaper just to get a new key-switch.
2005 Tennant ATLV 4300 All-Terrain Litter Vacuum (A55851)
2005 Tennant ATLV...
LMC G500-500A 72" Grapple (A56469)
LMC G500-500A 72"...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
2006 iDrive...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
Trump 2028 Metal Decorative Wall Sign (A55853)
Trump 2028 Metal...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
