Buying Advice Much time looking, down to the last question
   / Much time looking, down to the last question #1
GuadGrassfed
Guadalupita, NM
Ferguson TO-30, Kioti DK55
After using TBN for many years to read up and educate myself on tractors, I have finally gotten on board with my first post. I'd like to thank the hundreds of people whose contributions I've read and researched that have greatly benefited me. Its been like a college course on equipment: how to evaluate, size, maintain, use and purchase the right machine. Its a gold mine of information!
I'd like to think that my situation is slightly more complicated than average. I have a small ranch by western standards but of course we don't have very much dry-land farming here so we don't need to plow or mow. I run livestock and they eat grass that gets banked over the summer and is fully used-up over the winter. My tractor needs are for fence-post holes, modest road maintenance, handling round bales, plus some brush clearing and assorted FEL chores. The land is reasonably level for being in the mountains, elevation is about 7200', although I have read all the posts about how to make you machine more stable and less prone to rollover since we have plenty of incline (over 500 feet in a quarter section in places), and I plan to use loaded R-4s since its rarely muddy here and I like the lower profile.
My requirements lead me to look at the medium to large utility tractors: Kioti DK55, Kubota MX5100, the Deere 5000 series, etc. No need for cab, it's usually sunny all winter :thumbsup: My bottom-line list of "must-haves" are: 50hp machine (with matching loader for say 2500# lift at the pins), 4WD, TURBO (primarily for altitude compensation - at 7000' I'm giving up over 20% of my hp without it), and possibly HST since I think its advantages match my average use better than gear (though I don't have any issue with using a gear). I'd guess my average use per year might be 150-200 hours.
The last major item is The Dealer, and you can imagine it is sparse around here. I read on TBN where people have every dealer within 15 miles of their place: here its about 250 miles. It turns out that one of my closest dealers (80 miles and over a 10,000' mountain pass) is the one I prefer: long-time record of customer satisfaction, small town, wants the business (not lots of it here), knows how to deal with customers located far away. The dealer has therefore lead me to consider his brand quite strongly: Kioti. Luckily, I think Kioti appears to stack up rather well (thanks TBN for the info).
Therefore, I am faced with the fact that the Kioti line doesn't have much turbo. The DK55 is probably the best choice (I think?) but it doesn't have HST, just gear. I'd really like to buy Kioti although Deere and Kubota and possibly others have this rare combo: 4WD, turbo, 50hp, and HST ($$$). Mahindra, LS, TYM and others don't seem to have the same combination of these features. Kioti isn't perfect, but its just the tranny choice, the rest seems to line up. OR, I can chuck my strongly-held beliefs about turbo and altitude and get a DK50HST. Price differences between these two choices not significant to me.
Another thought I haven't seen written about: is hydraulic performance impacted by reduced HP of a naturally-aspirated engine at altitude, or would the tractor continue to pump out the same GPM with understandably reduced power for pulling and PTO chores? That might lead me to go to the naturally-aspirated HST all else equal.
So, my dilemma is to either forsake my goal of a turbo machine and get the Kioto HST -- or get a geared turbo model (DK55 presumably only choice) and just get good at running it. I'm mid-50s and the legs are still OK, but i certainly understand the point of view expressed here that the clutch can be a pain as you get older:eek:. Thanks in advance for any advice you might share-- recognize there is no objectively right choice but its still quite helpful to hear educated opinions.
   / Much time looking, down to the last question #2
Performance is a relative term, but at reduced horsepower, your flow rate may not be quite as good, but your pressure developed in the loader cylinders will still be the same, as that is a function of the Pressure relief valve. It may have slightly reduced response, in other words, the cylinder may not extend quite as fast, but it will still pick up the same load. I doubt the difference would even be all that noticeable. I think hill climbing with loads might be more noticeable. But the DK50se is the same basic tractor as the DK40se with 10 more horsepower. So you are starting with a stronger engine to begin with.
   / Much time looking, down to the last question #3
What about an RX6620 power shuttle? Go up in HP to compensate for altitude. Power shuttle reduces clutching. Looks like a really nice tractor to me.
   / Much time looking, down to the last question #4
2000 rpm is 2000 rpm the hydraulics will be the same but cost HP to get there. Get the DK 50.
   / Much time looking, down to the last question #5
Yes, with reduced HP using the hydraulics will have a greater impact on the engine (ie: lifting the loader and holding the lever until it goes into relief would bog the engine down more than at a lower altitude).
Aaron Z
   / Much time looking, down to the last question #6
I'm there with you at the mid-fifties age and haven't yet lamented having a shuttle. If you stay with the Kioti brand ( good choice in my biased view), given having to choose between more power and HST, I'd take the power.
   / Much time looking, down to the last question #7
Good advice and with the grade you describe you would be much happier with the power shuttle.
Appreciate the opinions thus far. I may price the RX (although its full Tier 4 - not sure I wanna be first). I can see that I am going to need a large silver dollar for the coin toss...
   / Much time looking, down to the last question #9
I'd look hard at LS U5030, no turbo but a full 3.3l machine. All the right stuff, Mitsubishi engine s4s is unapproachable. HS
Looking at the U5030: it is a turbo machine. Awesome specs, considering.
We do NOT accept credit cards as payment. (A50120)
We do NOT accept...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
Kohler 30 Generator (LOCAL TOWNSHIP) (A50774)
Kohler 30...
Husky Tandem Tank Spreader (A50774)
Husky Tandem Tank...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
