MTD yardman push mower surging
   / MTD yardman push mower surging #1
AroniaFarmer
Bronze Member
Sioux City IA
TYM T603 52' Ford 8N
I have just recently got a free yardman push mower. It looks like it has a Honda clone engine on it. When I got it home one governor linkage was off, but nothing else looked bad on it. I put new gas in it and started it. It was surging and running rough unless the choke was on or it was under a heavy load cutting some tall grass. Is this a governor issue or a carb issue?:confused:
   / MTD yardman push mower surging #2
Carb needs cleaned. But check the price of new carb, because kit plus time may cost more than the carb itself.
I cleaned the carb with carb cleaner and blew it out with compressed air over 2 times now and it still runs like crap. I think I am going to buy a new carb for it
   / MTD yardman push mower surging #4
Make sure you have good gas flow into the carb. Things like junk clogging or partially clogging the fuel line, or stick float needle valve can cause your symptoms.
KENWORTH T/A DAY CAB ROAD TRACTOR (A52706)
KENWORTH T/A DAY...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
2011 Ford F450 Diesel with Just 156638 Miles (A55218)
2011 Ford F450...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A55218)
2022 Gravely...
