MTD "Junkyard special"
   / MTD "Junkyard special" #1
Automan29
1981 Cub Cadet 782
Hello, I'm working on a 1992(?) MTD Task Force riding mower with a Briggs 12 hp I/C, found on a scrap heap. It was in pretty rough shape, but the engine looked decent enough so I thought I'd give it a chance. The wiring in this thing was positively butchered. All the safety switches (Seat, deck, reverse, etc) were bypassed straight from the coil to the ignition switch (orange wire). I even found another ignition switch under the dashboard, still tapped in to the wiring! After untangling this mess, believe it or not, I actually got the engine to start. It runs beautifully other than needing some carb work. The trouble is it will not shut down by switch. I have to pull the plug wire to get it to stop. the engine is a model #281707, sitting on a model #95179 (130-431E62) MTD mower. I have a single black wire with a round connector from under the starter that appears to connect to the red wire on the 5-post ignition switch which also connects to the headlight circuit. My magneto appears properly grounded. The wiring diagram I found mentions a yellow wire coming from the engine to the switch but I see nothing. There are two yellow wires tied together coming from the harness on the switch that have been clipped. They connect to the bottom post on the 5-way. Any thoughts?
Turns out the yellow wire was a second ground lead running up to the ignition switch from the coil. Someone must have removed it during their "repairs". Everything is working properly now. Time to rebuild the carb.
2022 WEILER S350 SKIDDER (A60429)
2022 WEILER S350...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2013 Ford Escape SUV (A59231)
2013 Ford Escape...
2021 Ford Mustang Mach-E AWD SUV (A59231)
2021 Ford Mustang...
2412 (A60432)
2412 (A60432)
2019 CATERPILLAR 299D2 SKID STEER (A60429)
2019 CATERPILLAR...
