MTD Brake issues... PLEASE HELP!!!
   / MTD Brake issues... PLEASE HELP!!! #1
rgs03833
Haverhill, MA
MTD 660, 690 - John Deere 60, 70, 108, 2 of 111, 111h, STX38
Hi all,
I just got a MTD Tractor Mower from a friend for cheap. I'm gonna use it for Snow Removal this winter. Everything seems to be fine, I was able to push the Mower back and fourth to put in the truck to drive home. When I got it home, I took the Mower Deck / Blade off since I don't need it, after that I was able to push it on my deck for fine tuning...
Now the Brake is STUCK I think.... If I start the Tractor I am able to drive back and fourth... and Neutral works too... But if I turn the engine off, key is out and the Tractor is in Neutral, parking brake is released. I can't move it anymore... It seems the Brake is LOCKED UP!!!
Please help me!!!
Thank you!!!!!
   / MTD Brake issues... PLEASE HELP!!! #2
Is this a Gear or hydrostatic transmission? If it's Hydrostatic, there should be a knob on the back part of the tractor between the wheels that you pull to have it free wheel. At least on mine :p
Is this a Gear or hydrostatic transmission? If it's Hydrostatic, there should be a knob on the back part of the tractor between with wheels that you pull to have it free wheel. At least on mine :p
OMG..... It WORKED!!!!
It is a hydrostatic transmission. It was kinda hard to find cause grass was everywhere and stuck in there, and since I know NOTGHING about this, first time owning one... But mechanical inclined, I was able to find it quickly.... But with your help of course :)
THANK YOU !!!:D
THANK YOU, THANK YOU... GLAD YOU ARE AROUND ;)
   / MTD Brake issues... PLEASE HELP!!! #4
No problem, glad it worked :thumbsup: (might have been easier if I re-read my post... I changed "...between with wheel..." to "...between the wheels...") :eek:
Hehe....
Yah, I looked at both just incase hehehhee....
It was not behind - behind... But it was between on the Front of the behind wheels... It was not a knob, but a contraption of some sort. When I saw the Grass behind it, I knew that it must be what you are talking about.
I took all the Grass off, then there is a Spring and a Stick that stuck to it, I wiggle that stick and there is a part that moved, but more Grass was behind there, so I Clean it all out, then that stick moved freely... The Spring does NOT spring back, so I think it was the problem. But once I did that, I pushed it and it moved, so I knew that was it.
I might have to take that Spring out and fix it and put it back. I don't want to go under it when it's Snowing out, LOL
But you did point it to the right Direction tho, I'm glad people like you are around when I was pulling all my hair out, LOL
Did I tell you I'm all BALDED now, J/K LMAO
Thankx again!
KUBOTA M5660 SU TRACTOR (A52706)
KUBOTA M5660 SU...
2012 JCB 930 ROUGH TERRAIN FORKLIFT (A52705)
2012 JCB 930 ROUGH...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
