MTD Brake issues... PLEASE HELP!!!
/ MTD Brake issues... PLEASE HELP!!! #1
rgs03833
Haverhill, MA
MTD 660, 690 - John Deere 60, 70, 108, 2 of 111, 111h, STX38
Hi all,
I just got a MTD Tractor Mower from a friend for cheap. I'm gonna use it for Snow Removal this winter. Everything seems to be fine, I was able to push the Mower back and fourth to put in the truck to drive home. When I got it home, I took the Mower Deck / Blade off since I don't need it, after that I was able to push it on my deck for fine tuning...
Now the Brake is STUCK I think.... If I start the Tractor I am able to drive back and fourth... and Neutral works too... But if I turn the engine off, key is out and the Tractor is in Neutral, parking brake is released. I can't move it anymore... It seems the Brake is LOCKED UP!!!
Please help me!!!
Thank you!!!!!
/ MTD Brake issues... PLEASE HELP!!! #2
Is this a Gear or hydrostatic transmission? If it's Hydrostatic, there should be a knob on the back part of the tractor between the wheels that you pull to have it free wheel. At least on mine :p
Is this a Gear or hydrostatic transmission? If it's Hydrostatic, there should be a knob on the back part of the tractor between with wheels that you pull to have it free wheel. At least on mine :p
OMG..... It WORKED!!!!
It is a hydrostatic transmission. It was kinda hard to find cause grass was everywhere and stuck in there, and since I know NOTGHING about this, first time owning one... But mechanical inclined, I was able to find it quickly.... But with your help of course :)
THANK YOU !!!:D
THANK YOU, THANK YOU... GLAD YOU ARE AROUND ;)
/ MTD Brake issues... PLEASE HELP!!! #4
No problem, glad it worked :thumbsup: (might have been easier if I re-read my post... I changed "...between with wheel..." to "...between the wheels...") :eek:
Hehe....
Yah, I looked at both just incase hehehhee....
It was not behind - behind... But it was between on the Front of the behind wheels... It was not a knob, but a contraption of some sort. When I saw the Grass behind it, I knew that it must be what you are talking about.
I took all the Grass off, then there is a Spring and a Stick that stuck to it, I wiggle that stick and there is a part that moved, but more Grass was behind there, so I Clean it all out, then that stick moved freely... The Spring does NOT spring back, so I think it was the problem. But once I did that, I pushed it and it moved, so I knew that was it.
I might have to take that Spring out and fix it and put it back. I don't want to go under it when it's Snowing out, LOL
But you did point it to the right Direction tho, I'm glad people like you are around when I was pulling all my hair out, LOL
Did I tell you I'm all BALDED now, J/K LMAO
Thankx again!
Barrel (A64557)
Barrel (A64557)
2022 EZ-GO ELITE...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2006 KOMATSU FD80T-8 FORKLIFT (A67148)
2006 KOMATSU...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
