MTD 5hp Briggs & Stratton chipper/shredder
   / MTD 5hp Briggs & Stratton chipper/shredder #1
dcollins
Motor runs only on choke. When choke is opened , engine will die. What is the problem?
   / MTD 5hp Briggs & Stratton chipper/shredder #2
Clogged port(s) in carburetor.
   / MTD 5hp Briggs & Stratton chipper/shredder #3
In addition to what Willl said it could also be clogged/restricted fuel filter or line. Also if the fuel tank is below the carburator it could be the diaphram in the carburator.
   / MTD 5hp Briggs & Stratton chipper/shredder #4
On an old worn engine, a burned exhaust valve could suck air on the intake stroke which makes the mixture too weak unless the choke is on.
   / MTD 5hp Briggs & Stratton chipper/shredder #5
Any smoke and if so what color? And what color is the tip of the spark plug?
   / MTD 5hp Briggs & Stratton chipper/shredder #6
This is a real old thread but it's exactly the same problem my Briggs has. No smoke, smells like it is running rich but won't run if choke is opened. Compression seems fair. One backfire pop when you turn it off.
Is there a way to check for a burned exhaust valve without taking the head off?
Thank you,
Jeff
   / MTD 5hp Briggs & Stratton chipper/shredder #7
The way gasoline is today clogged jets limiting fuel delivery happen to a lot equipment with small engines that are not run often. Especially if not using like Star Tron or another brand of fuel additive regularly .
IMO thoroughly cleaning the carburetor would the first step on my list of things to do! :D
   / MTD 5hp Briggs & Stratton chipper/shredder #8
The way gasoline is today clogged jets limiting fuel delivery happen to a lot equipment with small engines that are not run often. Especially if not using like Star Tron or another brand of fuel additive regularly . IMO thoroughly cleaning the carburetor would the first step on my list of things to do! :D
That's easier than opening the engine. Will give that a try first. Thank you!
Sent from my iPhone using TractorByNet
   / MTD 5hp Briggs & Stratton chipper/shredder #9
DFB,
Finished the carb rebuild and reassembled the blower. Wow! That thing runs like a Tasmanian Devil in a Tornado. Thank you! So much better than tearing the engine apart.
Jeff
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
UNUSED Single Stall Portable Toilet (A53117)
UNUSED Single...
1999 Yale 3,500lb Electric Forklift (A51691)
1999 Yale 3,500lb...
Husqvarna RZ5426 Zero-Turn Lawn Mower (A53117)
Husqvarna RZ5426...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
