Ballast MT372D - front end weights
   / MT372D - front end weights #1
HalReh
Jacksonville, FL
Mitsubishi MT372D
I am new to the list; my 372D has worked well for many years, but I wish I had purchased front end weights when I bought it many years ago. The front wheels often leave the ground when loading it on a trailer. Can weights be purchased or is it easier to "jury-rig some weights on the front end?
   / MT372D - front end weights #2
They can be purchased at any tractor dealer but they are very expensive. Sometimes you can find used ones but I've found they're also expensive. Try backing your tractor onto the trailer. That's what I do.
Eugene
   / MT372D - front end weights #3
A welder and some heavy can make some fine weights.
I used two 25" cut sections of RR track, "I" beam and some other assorted gussets and came out with 179lbs of ft. end weight that doesn't look bad. I can carry a 35gal tank of water on a frame or mow with a 42" BH witout getting air on the ft. end.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
UNUSED AGT QUICK ATTACH 72" VIBRATORY ROLLER (A51248)
UNUSED AGT QUICK...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
40' High Cube Multi-Door Container (A50123)
40' High Cube...
ECHO CS4010 CHAIN SAW (A51248)
ECHO CS4010 CHAIN...
