MT372 Range shifter trouble
   / MT372 Range shifter trouble #1
D40
My gear range shifter quit on me today so it stays in the low range all the time regardless if it's in the Low or Hi position. Is there anyone who has had this problem and might know what it is that is causing this.
Thanks, David40
   / MT372 Range shifter trouble #2
Most likely pin or bolt in the linkage. it the shaft turns with the leaver then the problem is inside the gearcase. you will have to remove the seat and the hudrolic control unit to get to the gears and linkage. not realy so bad I have opened the gear case on my beaver III several times.
John Deere PT Land Leveler (A50123)
John Deere PT Land...
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2016 FREIGHTLINER...
2020 JOHN DEERE 7R210 LOT IDENTIFIER 163 (A53084)
2020 JOHN DEERE...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
UNUSED CFG INDUSTRIAL MH12RX EXCAVATOR (A51247)
UNUSED CFG...
2022 Caterpillar 310 Midi Excavator (A51691)
2022 Caterpillar...
