mt372 parts?
/ mt372 parts? #1
oldmt372
Nicktown, PA
mt372
Hi, new old guy here. I'm just tryin to keep the oldmt372 up and runnin...Where should I be looking to find mt372 parts? Is there a parts price guide to look at, so I know I'm not gettin ripped off on prices? Your help is greatly appreciated.
/ mt372 parts?
It seems everyone is the middle man. What should I be paying for each of these... engine fan, the coupler that comes off the damper pully on the mower and a set of rear tire chains?
/ mt372 parts? #5
I have no idea on prices for those, I've never bought those parts. Why not call them and find out?
Tire chains could be sourced nearly anywhere, and probably replaced with pickup tire chains.
/ mt372 parts?
I should have clarified that I mean't these actual tractor salvage places are the middle man because the first 2 places I called during business hours and still could not get a person and have to leave a message and they would get back to me. The last place, the guy said he would have to see if he can locate the parts somewhere. More than likely, at some point, I'll save myself the trouble and end up junking the entire tractor because I am not going through the headache and anxiety for the parts witch hunt. Thanks for trying to help.
/ mt372 parts? #7
The tire chains and fan should be easy to find or at least get a substitute of something reasonably functional. Even if you have to pull the shroud off and install an electric fan, or substitute a similar Kubota or Yanmar fan or hub, you'll be able to requisition a fan of one type or another.
The coupler may be tricky, but it's not unachievable. You can get chain couplers from Surplus Center, Hub City, and other places. I've had a special coupler built from a splined coupling and a piece of plate steel to fit the front of my damper pulley to power a hydraulic pump. Even if you cannot weld, it should be a simple job for any machine or fabrication shop. If you have the components up the coupler, you'll be able to get something to work.
/ mt372 parts? #9
Man, a whole lineup of projects! Good thing its far far away from me.
/ mt372 parts? #10
Yeah no kidding....he is close to me and i have to avoid going there at all costs.
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
1500 Gallon Stainless Steel Tank (A64127)
1500 Gallon...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
