MT372 issues
   / MT372 issues
Well you are pretty much there. You'll want to remove the piston rod from the lift fork. It should be a cotter pin and shaft, and it should still be loose. You can then get something in there to drive the piston back forward in the bore. You should take off the cylinder head (the part behind the drop speed knob) this will allow you to get a hone in there to clean it up a bit once the piston is out.
When you drive that out you will need a pretty big hammer (5 pounds probably-that claw hammer in the picture isn't likely to do it) and a large brass punch. Just make sure you use the brass punch. I'll freely admit that I was hesitant to whack on that sucker, I showed it to a guy at a local tractor repair place in about 3 smacks with the hammer he freed it...No charge...So be assertive with it :)
For a hone I just used a regular 3 stone cylinder hone any auto parts house should have one. Don't go crazy on honing you just want to remove any crud, not resize the bore too much. Get a new o-ring and you are golden.
Unrelated...those weights you have on the back axle are pretty interesting.
Skylark, thank you for all your guidance. I was able to get the hydraulics working again! I tried using a bad punch and a 5lb hammer. I bent the neck out of that brass punch. I decided to use my rose bud (propane flame thrower) to warm the cylinder and the cylinder head. Not to cherry red but hot enough to brake the hold of the rust. I finally freed the cylinder head and removed it from the cylinder. Where the head was locked in place, the cylinder was rusted rusted 360 degrees. I used a 3 stone hone as suggested. First medium grit then fine. When I was finished it looked and felt almost new. I looked at the o ring and to my suprise it was in great shape. I cleaned out the reservoir and used high temp silicone as the sealant. I finger tightened all the bolts and waited about 3 hours and then torqued to specification. I couldn't reuse the washers on the banjo bolt so I replaced them with copper washers. I filled with fresh fluid and tested the system. Works like a brand new tractor. Not a single leak anywhere! Holds weight and lowers smooth as could be! As for the weighted rear wheels, thanks for noticing. They were on there when I got the tractor. Can't wait to get some work done now. Thanks again to everyone who helped out.
   / MT372 issues #13
Does any one know where to buy glow plugs for the MT372? email me
   / MT372 issues #14
Hi, I have an mt 372 with a front loader. When I bought the tractor, the loader work only on warm weather, but here it's winter and we have had a lot of snow, that we remove with a small snow blower. When I use the tractor and the loader, the hydraulic oil go to the engine and when it's full of oil, it reevs at full speed. I change the oil seal between the two parts of the pump, and the problem is less, but still there. What I can do to correct it? I use AW 32 hydraulic oil.
Husqvarna 120 Chainsaw (A48837)
Husqvarna 120...
120in Fork Extensions (A49346)
120in Fork...
New Holland 55 Pull Type Rake (A48837)
New Holland 55...
2020 CHEVROLET 2500 CREW CAB SERVICE TRUCK (A50459)
2020 CHEVROLET...
2003 International 4200 Crew Cab Landscape Truck, VIN # 1HTMPAFM13H594121 (A48836)
2003 International...
2007 Ford Econoline Van, VIN # 1FDWE35SX7DB47562 (A48836)
2007 Ford...
