MT372 help brakes
   / MT372 help brakes #1
andyroo33
UK
mitsibushi mt372d
As a forum member was so helpful, they put me in the right area for my hydraulic issue, thought lets try again.
Does anyone have details on the brakes, mine seem to be worse than useless.
When checking the rod linkage from the pedal, all seems fine until I reach the rear area, where the rod terminates, the rod moves but nothing else does.
Can I just remove the cover at this point, anything likely to 'pop' out?
Any diagrams available?
I need a manual but hard to come by in the UK
Thanks in anticipation
   / MT372 help brakes
Thanks, that does look simple, will look in due course
   / MT372 help brakes #4
Take everything apart and clean with brake clean spray. Take some sandpaper and scuff the pads and drum. Make sure the arm (2) can pivot in the hole in the cover. Clean that too and put a very small amount of lube on those parts. Make sure the springs aren't broken.
   / MT372 help brakes
Yup all sorted now, thanks yet again
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
2022 Kubota KX71-3S Mini Excavator (A52377)
2022 Kubota...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
Adams 5T HC Spreader (A55301)
Adams 5T HC...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A55218)
LIKE NEW 2023...
