kempfat
This is my MT372. Recently, I believe has developed a clutch issue due to my carelessness. I was revving the engine with the tractor in gear with my foot on the clutch when my foot slipped off the clutch. When my foot slipped off the clutch, the tractor jerked forward violently. I gained control of the tractor by pressing the clutch. I released the clutch slowely and the tractor started to move in first. I thought all was good but it wasn't long before the tractor started to slip in and out of gear by itself. The sound of metal could also be heard clanking around in the clutch area. So with that being said, I have decided to split my tractor. This is something that I have never done and I don't have a manual pertaining to the clutch assembly or its removal. I have taken photos of the process and decided to share on this forum / post. Hope this helps some folks with issues that they may come accross...
Here are the steps that I have performed to split my tractor. If you have a manual, use it!
ON A HARD (Concrete and or 3/4 Plywood)FLAT LEVEL SURFACE:
Replace bolts in holes once items are removed so they don't get lost!
Step 1: Disconnect and remove the battery.
Step 2: Drain all hydraulic fluid. I also drained all other fluids because it was due.
Step 3: I removed the seat, tool box and fenders to take a peek inside the shifting gear box. I needed to rule out any destroyed gears and to see if debris or water were present. To my surprise, squeaky clean and no moisture present.
Step 4: I disconnected all electrical components, oil pressure gauge, glow plug indicator and light switch and removed the dash. I also turned off my fuel line and removed the tank and tank mount. You also have to disconnect any linkage from the hand throttle.
Step 5: Disconnect the hydraulic lines from the pump. I found this to be convenient.
Step 6: With everything out of the way, block your rear wheels. Use a floor jack with wheels to lift the tractor from the front ever so slightly. Install blocking or cribbing under the back half of the tractor and then let the tractor down. Both front tires should be on the ground.
Step 7: Place the jack under the front axle. (I felt comfortable doing this because I had extra weight on the front) and raise the jack so it is snug to the axle. Have a safety block in place for when you split the tractor. You don't want it to fall on the ground! Once that is complete, remove all the bolts holding the two tractor halves togeter. Leave the top bolt in but loosen it. That way you can get an idea on what your tractor is going to do once you break the seal.
Step 8: Ask a friend to help you with this part! Ensure that you are both ready. Each person grabs the front bumper and someplace close to the dash area to stabilize the front half of the tractor. Remove the final bolt and pull the front half from the back half. The back half should not drop or move.
Step 9: Remove the bolts around the pressure plate and remove the pressure plate.
This is where I stopped. There were small thin metal pieces between the pressure plate and the clutch.
The clutch, pressure plate, and throwout bearing looked to be in great condition. I have no idea where that metal came from. The only place that I could see that it may have come from is the hole where the drive shaft/gear goes into the engine. Is there a shim sleeve or something that goes in there? Feel free to take a look at the photos. I would greatly apprecieate any feed back/help, or a manual if anyone has one to spare. Thanks!
