MT235E Front Axle Oil
   / MT235E Front Axle Oil #1
southerniltractor
Caryle, IL
Kioti DK40se HST with FEL, Simplicity Landlord, JD130
Howdy folks,
I'm a Kioti guy, but I'm currently helping my neighbor service his LS MT235E tractor. We discovered his front axle is low on oil and I'm trying to source the correct product for this application. The owner's manual states a requirement for API GL4 SAE 80W and a recommended product of EPK80W90 from S-OIL Total Co. Ltd.
The vast majority of gear oils I can find are rated for GL5.
Now my concern. I own Korean and US cars with manual transmissions and they all require GL4 due to bronze and other yellow metal transmission components that will react negatively to the additives in GL5. In in my vehicles, GL5 is not backwards compatible and can damage those gearboxes. I'm concerned his front axle may have similar components and potential problems from the wrong oil. Also, my Kioti and other small tractor brands fill the front axle with hydro oil at the factory and I want to add only compatible fluids to his machine. The owner's manual does not mention this possibility, but I don't want to screw up my friends tractor.
So, what do you guys use in your front axles?
Thanks,
Mike
   / MT235E Front Axle Oil #2
   / MT235E Front Axle Oil #3
Myself I'd use an Amsoil gear lube this one actually specifies good for brass;
   / MT235E Front Axle Oil #4
Best choice is https://www.amsoil.com/p/severe-gear-80w-90-agl/
Use in differentials, manual transmissions and other gear applications requiring any of the following specifications: API GL-5, MT-1, MIL-PRF-2105E, Dana SHAES 234 (Formerly Eaton PS-037), Mack GO-J or other GL-5 based specifications from vehicle manufacturers, including Ford,* GM* and Chrysler.* Can also be used in axles where an API GL-4 lubricant is recommended.
This is what I use.
   / MT235E Front Axle Oil #5
Howdy folks,
...I'm currently helping my neighbor service his LS MT235E tractor. We discovered his front axle is low on oil..
Thanks,
Mike
This seems to be common on smaller (40hp and under) LS tractors as several have noted the same on different forums. Most of us have had to add 1-2 quarts total over the first 20 hours.
I checked it upon delivery and added just a little and then continued to check it every 2-3 hours and always had to top it off until about the 20 hr mark then it was staying full.
Someone suggested it was due to 80 gear oil being fairly thick and just takes a while to flow into all the small areas and/or was filled while it was cooler weather.
That was my thought as well. I stuck a clean screwdriver into the check port and determined there is oil in the axle, but not reaching the dipstick. Fortunately, there was oil there and it was both clean and not burned smelling. I'll top off his axle with this I have on hand for my cars which use this oil.
   / MT235E Front Axle Oil #7
As soon as it says GL-5 on the bottle, put it back! Like the OP stated, GL-5 is not backwards compatible. If the specification is for GL-4 only, then use GL-4 only. Even if the bottle states it can be used in axles where an API GL-4 lubricant is recommended. I get this info from doing my transmission in my Toyotas. But I get it, a Toyota pickup is not the same as a front axle on a Korean tractor.
The OP is correct on the reasons why we need to use GL-4 only in gear boxes that contain brass, bronze, or copper. GL-5 will dissolve that metal. It's not fast, but it will happen, and will destroy that gear box over time. That is why I use GL-4 in my manual transmission pickup. But due to availability and cost of GL-4 oil, I do use GL-5 in my differentials and transfer case on my pickup, only because there is no metals in those gearboxes that would be damaged. Likewise, implement gearboxes, I use the GL-5 oil in. If one of those gearboxes fails, they are easy enough to rebuild or replace. A front axle on my tractor is not.
I do wonder if this is the reason so many hubs develop leaks on these tractors, people using the wrong oil? I don't think so, but it is interesting. For me and my tractor, I'm not sure if there are soft metals in the front axle, but the manual states API GL-4, so that is what I will put into it. I scrolled through the shop manual looking at the parts in the front axle, but they do not show what type of material they are made out of. It's not something I'm going to risk.
   / MT235E Front Axle Oil #8
   / MT235E Front Axle Oil #9
I have no issue using Amsoil GL5 in this application. Here is why,
Not arguing with you or the information you posted. Just highlighting some things. Everyone is entitled to run whatever they feel is correct in their own machines. The Tractor Police will not come and arrest you for using GL-5 in your front axle, but...
From the mroilguy link you provided:
"Some GL-5 oils contain EP additives, which can be damaging to yellow metals such as brass and bronze. For this reason, GL-5 should not be used in synchronized manual transmission. Despite this, it can be used in transmissions that are not synchronized without causing damage."
He is specifying transmissions, how the oil can damage the 'yellow metals' found in most synchros. Differentials, transfer cases, etc., do not have synchros, so using GL-5 is ok. However, the key information to take away from this is the 'damaging to yellow metals' part. In a tractor's front axle, is there 'yellow metal' in bushings, seals, gears? I honestly dont know. I havent rebuilt my front axle yet. However, the manufacture, the one who pays a team of engineers a ton of money to design the front axle, specifies the use of GL-4 in the front axle.
Based on that info, is GL-5 okay to run in a front axle of a 4 wheel drive tractor? Maybe. But I know that GL-4 is safe. I wish I could put GL-5 in my front axle. Its cheaper and easier to find, and probably safe, but I cannot, in good conscious, knowing the risks that will keep me up at night, put anything into my front axle other than API GL-4 gear oil.
   / MT235E Front Axle Oil #10
The Amsoil synthetic GL-5 does not damage yellow metals and is safe, the specification data sheet specifically mentions that.
   / MT235E Front Axle Oil #11
This is what I use.
+1 on the severe gear goo... good stuff. Use it in my truck and tractor.
Howdy all,
I've enjoyed reading the responses here. Funny how the topic lubricants can stir up some interesting conversation! In the end, I'll just square my neighbor away with some of the specified GL4 and advise him of the information gleaned here. When it is time to change the gear oil, I'm sure this subject will be revisited. For me, I'm conservative and always stick with what the manufactures specifies.
Be well,
Mike
   / MT235E Front Axle Oil #13
I now have about 25 hours on my MT335H and when checking all the fluid levels and greasing ect. I noticed I don't have a dipstick on my right hand front axle oil fill plug. On that page in the manual it shows a picture of the dipstick for the hydraulic oil on the fill plug but no picture of dipstick for front axle. It just says fill to the proper level. The bottom side of the plastic fill plug is just flat and it doesn't appear as though anything broke off of the plug. It looks low but how can I tell?
I have some Royal Purple Gear Max 75w-90w full synthetic that says it can be used in GL4 applications and will not corrode yellow metals in syncro transmissions. The manual calls for 80w-90w GL4. Would 75w-90w work ok?
Same thing on my friend's tractor. Look at the same location on the other side of the tractor. You'll see a white plug there. Remove the white plug (27mm wrench) and you'll discover your dipstick! We went through the same puzzle too.
Regarding GL4 versus GL5, you have probably already reviewed all the comments here. For me, I'll stick with GL4 and not induce any additional worry for myself. The weight you have should be fine.
   / MT235E Front Axle Oil #15
Why would they design it so you have to use a wrench to check the oil level but have a hand loosened plastic plug for filling the oil...seems ass backward! So you could check it in the field if needed and then fill it back in the shop where you keep the 27mm socket.
I just purchased 21mm,24mm,and 30mm 6 point sockets for my Tacoma diff drain and fill plugs.Rusted really bad...I'm lucky I got them loosened. I guess it's back to Amazon for the 27mm 6 point. Is that a metal plug for the dipstick?
I just got back from Fleet Farm and the only GL-4 they have is Mercury Marine 90W GL4 for marine lower units. It says it will work with up to 10% water in the oil.
Thanks for the information
   / MT235E Front Axle Oil #16
Ahh... Tacoma diffs... I know a thing or two because I've seen a thing or two. :cautious: Not exactly fun. Amazon sells spare plugs for a few dollars, fyi.
As far as the ass backwards on the plugs, for me, my manual specifies to check the front axle oil every 50 hours. So this is not necessary a 'field check' daily thing, like the engine oil. Typically, you're checking the front axle oil at the shop or garage, where tools are more available. That's not saying you cant, or shouldnt, check it in the field, but, you know what I mean. ;)
And 50 hours seems a bit... frequent for me. I check mine about once or twice a year. Not even sure of the hours. It's typically when I A) have the tractor in the shop for an oil change or something. And B) when I remember. :oops:
The fact that your tractors also have a dipstick (and a plastic fill port cap) is odd to me. Mine are simple threaded plugs, like on most diffs. A fill inlet with steel threaded plug, and a check port, again, with steel threaded plug. I'm just grateful they have the fill port and don't require oil to be pumped into the tiny check port!
All this to say, I have no idea as to why they would put a dip stick on the side of an axle with a steel screw, and a plastic fill port cap. I guess they assume the "check port" should be where you check it, and there really is not anything to damage a plastic cap on the top of the axle. If it were me, I'd probably replace that plastic cap with a steel one though. :)
   / MT235E Front Axle Oil #17
The "plastic fill cap" is actually a vented cap, relieves pressure buildup during use so the seals don't blow out.
   / MT235E Front Axle Oil #18
It all makes sense now!
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
CASE CX31B EXCAVATOR (A60429)
CASE CX31B...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
