Mt2201d starter
   / Mt2201d starter #1
Mitsnewbie
Mitsubishi mt2201d
Anyone have a part # for the starter ? Napa shows several different ones that all mount different. It would save me a couple hours of driving time. Thanks
   / Mt2201d starter #2
if you pull the old starter, it should have a manufacturer's tag on it somewhere. that will give you all the info you need. also lets you bench test to make sure it really is the starter. finally, you'll have the core with you that you can compare to what they pull off the back shelf & avoid the return trip for the core charge in the miraculous event that they actually have in stock and pull the right starter for you. if you can't find one available in stock, see who does their rebuilds & you might be able to take it there for the internals.
   / Mt2201d starter
The tractor is a couple hours away, I'll likely end up doing what you suggested. I was hoping to get one to take up with me.
   / Mt2201d starter #4
When my Mitsubishi starter failed I removed it and took it to a local starter repair shop. They identified it and ordered a new one. After a two week wait they had received the new one. I installed it. End of story.
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
SCAN TO RECEIVE TEXT UPDATES (A60429)
SCAN TO RECEIVE...
