MT2001 Trans/Hyd Oil Check plugs
   / MT2001 Trans/Hyd Oil Check plugs #1
sharpiepyg
Farmington Hills, Michigan
Mitsubishi MT2001
Hello, I'm a newbie to the Mitsubishi tractors and this website. So far I have found it to be very usefull. I purchased a few manuals for the trator, but I have yet to determine the location of the drain and check plugs for the hydraulic oil and transmission oil. I found the motor oil drain plug. That one was easy. Further back from that is another drain plug, that I'm not 100% sure if it is trans or hydraulic. I can't find the check plug for either. I have two filler caps, one right in the center on the trans (which I assume is the trans fluid) and the hydralic is further back by my left foot/wheel well. So based off that I don't have a shared system. Both manuals also seem to list two different oils for the transmission (GL-4 gear oil) and Hydraulic (10W or SAE20) Any ideas on where these drain plugs are and which/where the check plugs are? Better pics than the manuals show would be excellent!
Thanks,
SharpiePYG (aka Mike)
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
2014 VOLVO A40G OFF ROAD DUMP TRUCK (A60429)
2014 VOLVO A40G...
JCB 2145 (A47477)
JCB 2145 (A47477)
1744 (A60430)
1744 (A60430)
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
2019 VOLVO A45G FS OFF ROAD DUMP TRUCK (A60429)
2019 VOLVO A45G FS...
