MT180D sway chain rod
   / MT180D sway chain rod #1
PILOON
Super Star Member
North of Mtl,Que,Can (Ste Adele)
MT180D
Bad luck!
That rod that the sway chains attach to broke on the left side. It happened once before about 6-7 years ago. Sort of understandable as the intent is to prevent side swinging of drawn attachments but not meant to withstand strong side forces while pushing backwards.
In my case it is from snow blowing with a 60" blower and snagging the occasional boulder or root with a corner of the blower as I back into snow banks.
The last time I snapped it I simply used cold rolled shafting stock as a replacement and drilled ends for the pins.
The bad news is that tomorrow they predict - 28 degs and I have to work outdoors. BRRRR
Off to the machine shop in the AM to buy a length of shaft stock.
The good news is I am an old hand at doing this repair.HAH.( better said a VERY cold hands)
Unfortunately I can't wait for warm weather as warm just means more snow.
OH, TV weather (TV is on) predicts a high of -8 Thurs, well that's better than -28.
   / MT180D sway chain rod #2
Just don't test the old tongue to cold metal trick. Be safe out there.
Picked up a length of 7/8" shafting and next is to drill the end holes.
Called a neighbor who will let me use his garage for the surgery as minus 28 is just too much for these old bones. (especially laying in the snow plus I suffer from renaud's syndrome* in the hands.)
If I remember I had to pull a wheel to replace that shaft.
* cold makes me lose all feeling,( like can't feel the difference between a razor blade and 1/2" bolt)
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
1981 LOAD KING BELLY DUMP (A53843)
1981 LOAD KING...
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
